Old 09-12-2020, 04:34 AM
Radbuster's Avatar
Radbuster Radbuster is offline
Default 2012 EC300 ?hlins STX shock fit on 2008 EC200?
Hi guys,
Tried searching but could not find the answer.
Does anybody know if a shock from a 2012 EC300 Racing/Nordic Edition, an Ohlins STX 46, will fit a 2008 EC200 that had a Sachs?
I blew up my gas chamber when running too much oil and can't find parts, and was offered a good deal on this used shock.
Any info?
mint 2008 EC200. Earlier bikes: Husqvarna WR125 '12, Husaberg FE450 '10, Sherco 4.5i '05, EC300 '07, YZ450 '03, WR250F '01, WR400F '00.
Old 09-12-2020, 02:18 PM
Anders's Avatar
Anders Anders is offline
Originally Posted by Radbuster View Post
Hi guys,
Any info?
I doubt it. The frames of 08 and 12 are quite different, including the shock and linkage.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 09-14-2020, 10:46 PM
frankinberg's Avatar
frankinberg frankinberg is offline
07-11 are the same different after 12 they changed the frame
Old 09-15-2020, 03:33 PM
Radbuster's Avatar
Ok, thanks for the info guys.
Appreciate it.
Regards,
F
2005 ?hlins shock shawnyoung319 "Wanted to Buy" & "Want To Trade" 3 09-02-2020 11:58 AM
2012 ec300 fork and shock springs needed (heavy) Iceracer Parts 5 05-15-2018 01:30 PM
Gasgas EC300 Replica Factory Limited ?HLINS 2014 BSM2 Pictures & Videos 12 03-23-2015 01:28 PM
2012 YZ450F forks and front end on a 2008 EC200? darealickt Enduro Suspension 10 04-28-2014 12:10 PM
