Old 02-22-2008, 07:42 AM
steve steve is offline
Default Torque Specs
Are the torque specs for the head and jug on the links for this web site accurate? If not could someone give them to me?Thanks.
Old 02-22-2008, 07:50 AM
eff's Avatar
eff eff is offline
It's located on this page: http://www.gasgasrider.org/html/manuals__etc.html
Old 02-22-2008, 05:49 PM
PEB PEB is offline
Be sure to retorque the head and jug fasteners after a couple heat cycles. I didn't last time and sucked the base gasket out of alingment.
Paul B
Old 02-22-2008, 09:57 PM
jyellard jyellard is offline
Do you think the head and jug fasteners should be retightened on a new bike after a few heat cycles, or only after a new top end.
Also, are the above torque values applicable to lubricated fasteners or unlubricated fasteners?
I always lube the bolts on my bikes especially since so many connections involve dissimilar metals (steel and aluminum).
Old 02-23-2008, 06:42 PM
PEB PEB is offline
I don't know about the new bikes, I have never owned one(poor me).
Old 02-26-2008, 08:26 AM
oldgoat oldgoat is offline
( quote) Also, are the above torque values applicable to lubricated fasteners or unlubricated fasteners?
I'm almost 100% sure its for unlubricated nuts and bolts.
Old 02-26-2008, 01:42 PM
I generated that XL sheet eight years ago, probably time for an update. What seemed excessive in the GG manual was corrected with industry standard values for the relative fastener sizes and materials. No specs so assume dry fasteners. With Antiseize you can knock off up to 30% I beleive. Thats why I said elsewhere go lower on the T-clamp torque, as the bolts should be antiseized.
Old 02-26-2008, 07:52 PM
Yeah, after greasing the lower triple clamp bolts and torqueing them to the specs in the chart the forks seemed a little sticky. I backed them off a little, and the fork action improved.
I'll take 30% off for the lube. Thanks.
Old 02-26-2008, 09:30 PM
I'm down to 8 - 10Nm on the GG lower clamp with antiseized bolts.
05 De 300 Specs VORMAN Enduro Electrical & Wiring 9 11-14-2010 06:36 PM
Top End Clearances/Specs SpeedyManiac Enduro Engine - 2 stroke 4 09-24-2009 09:53 PM
rake and trail specs widebear Enduro Chassis & Body 9 01-28-2009 05:52 PM
ring gap specs jostby Enduro Engine - 2 stroke 9 10-27-2008 06:18 PM
Chain and Sprocket specs gasIdaho Enduro Chassis & Body 7 09-01-2006 04:03 AM
