did u establish which forks?as above look for the odd triangular nut in centre,thats pfp on 48's,not the hexagon inside the rim.the 48s on my 13 at stock damping have a lot of rebound which gives very sharp feel on slow technical sections,but when you up the pace its just too much rebound,over whoops the front kicks up and feels out of sorts with the rear.
simmo's settings are very similar too mine.IMO the most important one is the rebound(14 out also),this settles the front end down,pfp and comp to taste.clickers out from full in,pfp in from full out!stock is 2turns in(harsh),im on 1 in also,and within a couple comp clicks of simmo.take note of where your clickers/pfp are now for interest sake,and if both sides the same.count clicks in softly until full in,dont force,then click back out.rebound clicker on the bottom of fork tubes,comp on top.go softly on the pfp also,should turn easy enough but drags(almost as if theres a spring pressing on it from the inside!ha)
2013 ec200r
