Old 05-18-2014, 06:25 PM
iamovru's Avatar
iamovru iamovru is offline
OOOPS! Yep, 45mm. The suspension has been setup by Les, but if I can do the oil changes myself it would be a bonus. I used to do my KTM`s OC, but I never did the CC that I had.
15 Beta 300RR Race
Sold KTM 450EXC now moving over to RED! Looks like I found the right bike. Thanks REVERUP!
2011 GasGas EC300 "Stolen By A Scum Bag"
2009 450EXC Sold to Rapid Dog EURO Factory Anti-Hop slipper clutch, GPR V4, Akropovic Full Ti Exhaust, 2013 suspension and wheels.
2009 300XC
2005 525 MXC
2000 WR 400
1996 XR 600
1987 CR500
1990 KX500
Old 05-18-2014, 08:41 PM
Most OC forks are pretty much the same. Just have to be careful when threading the rebound assembly back onto the damping rod. Especially with the Sachs.
Old 05-18-2014, 08:48 PM
Back on topic, finishing touches complete.
Measured the preload on the springs at 3mm. Inserted the cartridge without the spring and marked the cart level with the top of the fork outer (compressed). Removed the cart and measured the distance from the mark back to the spring seat and recorded. Then inserted the spring into the fork and measured from the open end of the fork to the spring. Subract them and hey presto!
Then with spring in the outer, drop the cart back in and locate the lug in the foot.
Put the nut on the bottom and torque it up to spec.
Add oil (I went with 325ml)
Pull the outer fork leg up and thread onto cart, snug it up, make sure your clickers are where they should be, bleed screw is snug, and set aside. Repeat for the other leg.
Then package em up ready to go home.
Hope the thread helps out. Its not really anything that isn't covered in the Marzocchi manual, but sometimes its nice to see a few different pictures, and if anything it stimulates conversation.
Old 05-21-2014, 04:09 AM
Heres the link on the 45mms. Complete with pictures - http://www.scottysdirtbikespares.com...k-service.html
Old 06-08-2014, 08:48 AM
iamovru's Avatar
Thank You!!
15 Beta 300RR Race
2009 300XC
2005 525 MXC
2000 WR 400
1996 XR 600
1987 CR500
1990 KX500
Marzocchi 48mm CC Forks SolidPerformance Enduro Suspension 334 01-08-2019 07:32 AM
Marzocchi 48mm Challenge! Jakobi Enduro Suspension 21 08-02-2014 04:10 PM
48mm Marzocchi Manual Clay Enduro Suspension 5 04-11-2013 01:51 AM
Marzocchi 48mm 2nd service GMP Enduro Suspension 1 02-04-2013 04:16 PM
48mm Marzocchi warning! STM Suspension Enduro Suspension 17 03-22-2012 03:44 PM
