Old 08-02-2006, 08:59 AM
LTRace's Avatar
LTRace LTRace is offline
Hello Matt,
Here are the retail prices for a typical re-valve and setup that I charge;
Fork rework/setup including fluid and shims $149.95
Fork springs (with revalve) $85 ($14 off of retail)
Shock rework/setup including fluid and shims $139.95
Shock spring (with revalve) $90 ($15 off of retail)
Fork oil seals if needed (depending on application) typically $29 to $32 pair
As noted, this includes high quality fluid and valving shims. Most shops charge for each individual shim plus the fluid, this can add up really fast.
Thank you Matt,
Les
Les
www.lt-racing.com
Port Orchard, WA USA
Old 08-02-2006, 10:40 AM
MattR's Avatar
MattR MattR is offline
Thumbs up
Thanks Les for responding. I was hoping you would see your name in my previous post. I will get in touch with you this winter for reworking the front and rear.
Matt
Current: 2009 Yamaha FZ1
How to set float level. Revisited. gasgasman Enduro Intake/Carburetion - 2 stroke 48 11-10-2018 05:11 AM
Zokes oil level? jostby Enduro Suspension 2 06-20-2009 11:29 AM
Fork oil level ? Brian VT Enduro Suspension 4 03-10-2009 08:57 PM
LTR fork Oil PEB Enduro Suspension 5 09-10-2008 08:07 AM
5000-7000 ft. above sea level (jetting) Link Enduro Intake/Carburetion - 2 stroke 7 03-25-2008 01:45 PM
