2011 EC200 6days
Hi all,
New here but have been browsing for hours looking for some info regarding the carb and settings and jets. Completely stock bike and a freshly repacked exhaust, Settings the bike arrived with: PWK38 AS1(screw top) 178 main 42 pilot N1ED needle clip 2 from the top Slide #7 Runs incredibly rich and idles extremely low Will idle like normal and then drop to near nothing. Is my info correct in that the float needs to be at 16mm? I see many are running 175 or 172 mains I've replaced the reeds and adjusted the power valve. I ride in Cape Town South Africa from sea level to 500m Temps ranging currently from 10deg C to 20deg C I've got the following jets on hand Mains: 175,178,180 Pilots: 38,40,42 I ride mainly single track with a mix of rocks and steep up hills. Anyone got a good starting point for me to baseline this carb? TIA Last edited by slylux; 06-26-2023 at 08:34 AM. |
There is a sticky at the top of this section with a jetting database.
Mikuni was obviously a typo, its Keihin. Needle change is first thing you need to do, see threads.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
2011 gas gas xc 250 6days | ferreira241 | Used Bikes | 6 | 04-28-2014 05:58 PM |
metzeler 6days extreme pressure | Barton | Enduro Chassis & Body | 13 | 04-25-2014 02:06 AM |
12/48 vs 12/50 2011 EC200 | liv2day | Enduro Chassis & Body | 3 | 01-31-2014 11:11 AM |
Sprocket size for 2011 6days 300? | redrider | Enduro Engine - 2 stroke | 3 | 10-24-2011 02:58 PM |
