Pull the T piece out Josh, run the line from the right PV cover back to the air intake. Let the left PV drain to the atmosphere.
I doubt it's causing the fowling though. If jetting is right, plug is the right heat range gapped correctly, and you are still fouling I'd be looking at the rh crank seal. |
fuel coming out vent hoses when petcock switched to reserve | bluespark | Enduro Intake/Carburetion - 2 stroke | 11 | 07-29-2015 11:45 PM |
Silicone hoses | doddi1 | Enduro Product Announcements | 7 | 07-15-2015 08:45 AM |
Silicone Hoses 450fse | Zanderson | Enduro Engine 4 stroke (including EFI & Exhaust) | 2 | 06-19-2014 11:10 PM |
coolant hoses | adv rider | Enduro Engine - 2 stroke | 0 | 12-06-2013 01:36 AM |
Hoses | Fred1956 | General Discussions & Announcements | 3 | 01-19-2011 07:19 AM |
