Old 10-19-2006, 08:49 PM
MattR's Avatar
MattR MattR is offline
Default What's the best way to remove the master link plate after it's pressed on?
Here's my dilema:
I always have trouble getting the master link plate off after it has been pressed on. I use a chain press tool which is great for pressing the master link together. However, when it comes time to disassemble the chain... that outer plate is a pain to get off. Also, if you over drive the plate slighter during assembly and want to back it off a little bit... what's the best method to use?
My current method is typically to take a big screw driver and try to pry the plate from side-to-side. Slowly, I get it to walk its way off of the master link pins. Since this may cause the oring seals to get damaged, there has to be a better method.
What do you guys do?
Matt
Current: 2009 Yamaha FZ1
Old 10-20-2006, 10:56 AM
Brian VT Brian VT is offline
I usually just grind the ends of the pins off.
Old 10-20-2006, 12:31 PM
TeeJay TeeJay is offline
Yep that's what I did til I woke up and started using split links instead
No crap no hassle and never heard of anyone's coming off
Old 10-20-2006, 09:07 PM
MattR's Avatar
I should have stated that this is a non-riveted master link. I use the kind with a slide-on clip. After taking off the clip, you now have to get the plate off... this is when the struggle begins.
Do you guys use screwdrivers, another tool, etc. to get the plate off?
Matt
Old 10-21-2006, 02:40 AM
That's odd Matt
It should just pull off, maybe one or both of the pins are mishappen
They do have to be pulled off square though, if it's tight then I'd guess a screwdriver behind the plate would help
Old 12-01-2006, 09:07 PM
INABIL INABIL is offline
I use a non O-ring master link on my O-ring chain.
Bill
'03 EC400fse
'95 KX 250
Old 12-02-2006, 11:50 AM
JTT JTT is offline
I just gently walk them off with a screwdriver same as you. If your carefull you won't damage the rings.
No way you'll get DID VM series links off without somesort of tool (and yes I mean the split clip type). They actually press on. Can't install without tools either.
Old 12-15-2006, 05:43 PM
jim360h6 jim360h6 is offline
Default chain&links
i have a 2004 450 fse and it does not have a master link. i am the second owner. is this style chain O. E. M.? as for removing the master link. rotate rear wheel so the link is on the rear sprocket,pull clip then TAP the link out.
Old 12-16-2006, 06:26 PM
GMP's Avatar
GMP GMP is offline
Matt,
Just use a chain breaker. I have a large one and just work each pin a turn at a time until its free. Works fine.
Old 12-16-2006, 08:36 PM
MattR's Avatar
Matt,
I was afraid chain breaker would bend the master link since the other pin is attached. But like you said, if you do it one turn per pin then it should work ok. I'll give that a try next time. The screwdriver method works but seems like a caveman approach.
Matt
how do you remove the kickstart noobi Enduro Chassis & Body 13 09-22-2011 03:31 PM
is there a master link? mountain thumper Enduro Chassis & Body 4 07-09-2008 05:36 AM
How best to remove carbon from PV components? d2w Enduro Engine - 2 stroke 9 02-21-2008 09:03 PM
Periodically remove and re-fit all bolts? stay_upright General Discussions & Announcements 2 01-14-2008 07:56 PM
Another Master-link question FFRDave Enduro Chassis & Body 5 10-21-2006 07:48 AM
