Old 09-11-2011, 05:15 AM
Simmo737's Avatar
Simmo737 Simmo737 is offline
Default Anyone tried removing center bolt on lower triple clamp with sachs forks 2011?
Apparently it reduces harshness on sherco enduro bikes, allowing flex like a husaberg. Any experience with this out there, zoke or sachs?
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 09-11-2011, 05:54 AM
First I've heard of it.. Keen to hear more though..
Old 09-11-2011, 06:00 AM
noobi's Avatar
noobi noobi is offline
I think the binding they are talking about is only really an issue if you torque the bolts up too much. There's a table somewhere with appropriate torque settings, the ones in the manual are rubbish.
Old 09-11-2011, 08:01 AM
Bailey28 Bailey28 is offline
I think GMP or someone here said that if you keep going over and over the bolts to get to a torque spec, it could be any number, the number would be a lot higher than if you just tightened it once.
I was running my lower bolts very loose however every time I took minor spill, I had to find a tree and tap the wheel against it to straighten out the front end. Kind of like you did as a kid on a bmx bike after you roached it.
I have since tightened mine up to say, 7-8 foot lbs on the lowers and 12-14 on the uppers. My uppers came so tight from the dealer that they had creases in the tubes.
'10 EC300 -- very happy
Old 09-11-2011, 09:50 AM
husley's Avatar
husley husley is offline
Bronze Level Site Supporter
I know a pro offroad guy who removed the lowest of three (lower clamp) bolts on his KTM, he claimed it made it less harsh.
Anybody have the proper torque specs for the 2010 sachs?
2015 KTM 450 XCW
2014 350 XCF Wife's
2009 200 ec. Loving it
2007 Beta Rev 3 270
2007 KTM 200 XC Wife's
Public Lands belong to the Public
Old 09-11-2011, 10:09 AM
GMP's Avatar
GMP GMP is offline
Torque the two end bolts and just seat the center snug, thats it. It will be way too tight if you go over all three bolts to spec. Its not like a cyl head. Too tight and it will be harsh and wear the anodizing off the inside of the uppers in the area of the lower clamps. You can go surprisingly low on torque without a slipping problem. I run 9Nm with the Zokes. I see no reason why the Sachs should be any different as its clamp dependent not fork dependent.
Old 09-11-2011, 02:31 PM
ScottyR ScottyR is offline
Junior Member
I only run the 2 top bolts on my lower clamps.
Old 09-11-2011, 02:32 PM
husley's Avatar
Good to know......... thank you
2015 KTM 450 XCW
2014 350 XCF Wife's
2007 Beta Rev 3 270
Old 09-13-2011, 11:33 AM
thumperrider1 thumperrider1 is offline
Scotty, what NM on those lowers with the 2 tops only?
2018 XC300
Old 09-14-2011, 05:31 AM
stainlesscycle's Avatar
while we're at it - proper torque specs for the lower triple clamp bolts for wp???
manual says 22Nm. i'm assuming that's too high. i've run as low as about 7Nm but they work themselves loose... i don't loctite them, maybe i should...
07 ec300
www.stainlesscycle.com
2011 Sachs Forks - Tuner Info twowheels Enduro Suspension 7 06-17-2011 10:14 AM
2011 GG - fork & triple clamp conversion BrentMartell Enduro Suspension 9 03-16-2011 09:58 AM
