Old 09-28-2016, 09:12 PM
95jersey 95jersey is offline
Default Anyone know stock fork spring rate on late model 300's?
Can't find any reference
Old 09-29-2016, 01:32 AM
Anders's Avatar
Anders Anders is online now
According to the latest manuals the spring rate is 4.2 N/mm
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 09-29-2016, 03:24 AM
webmaster's Avatar
webmaster webmaster is offline
Administrator
Another option is that you can find a spring rate calculator on line - enter the specifics for your spring and it will tell you rate. e.g. # of coils, diameter of "wire", length, diameter, etc....
Just did a quick google and found this one...
http://www.pontiacracing.net/js_coil_spring_rate.htm
Late model near KY kendunn "Wanted to Buy" & "Want To Trade" 12 01-17-2016 11:51 AM
Fork model and stock springs 2007 EC300 Paynebrody Enduro Suspension 0 07-20-2015 04:14 AM
Measuring Fork Spring Rate Trick toadl Enduro Suspension 8 03-25-2014 01:34 PM
Stock Spring Rate in '11 Ohlins Shock? bputt Enduro Suspension 2 01-13-2011 01:47 PM
Fork Spring rate? JoshP Enduro Suspension 2 09-21-2006 03:19 PM
