Old 12-06-2022, 11:29 AM
fury1's Avatar
fury1 fury1 is offline
Default 2005 FSE 450 clutch help
Just picked one up...pretty good deal...owner states that the clutch drags in gear...I tried to adjust it at the two different lever points...but can't seem to get it to stop dragging...any ideas before I open it up and make sure it has all the washers etc...
It's a slipper clutch btw...and last owner got it from original owner and the clutch was all apart..so he said he fixed everything...well I know it's not supposed to drag...gonna start by back bleeding the master...then I guess lay it on the side and open the clutch cover and take it apart
Old 08-27-2023, 10:59 AM
KLRmurdercycle KLRmurdercycle is offline
I also picked up a 2005 in January. It has the Adler slipper too. Clutch was sorta sluggish. Ripped it a part and 5 of the inner plates seen heat at some point. Put a DP disc and plate kit in but as I tightened the 3 bolts down the one bolt tower collapsed.
Wondering if anyone has put a Rekluse or really any normal clutch assembly in instead?
2005 ec250 Rekluse auto clutch henrymark6 "Wanted to Buy" & "Want To Trade" 4 10-19-2021 08:27 PM
2005 EC 450 FSE Slipper Clutch Basket Wobble Mannmitch97 Enduro Engine 4 stroke (including EFI & Exhaust) 3 08-20-2021 09:24 PM
Clutch Basket and plate thickness - 250 2T 2005 bally123 Enduro Engine - 2 stroke 0 01-18-2016 02:59 PM
2005 450FSE starter clutch test? guzziboy1064 Enduro Engine 4 stroke (including EFI & Exhaust) 3 03-14-2014 09:09 PM
2005 450 Starter Clutch Blues meanmarv Enduro Engine 4 stroke (including EFI & Exhaust) 0 07-07-2013 12:18 AM
