Old 12-19-2023, 11:49 AM
Dario Dario is offline
Default Powervalve Orientation
What is the right orientation of the Powervalve?
When my valve is full trottle the ports left and right are also open.
Is right? I?ve seen some people on this forum saying the Ports have to be closed.
Here is a small video of how to looks now:
https://youtube.com/shorts/FAt8SKBTU...g0xB7CFKHgO2ll
Old 12-19-2023, 02:06 PM
I'm pretty sure they will fit only one way
http://www.gasgasrider.org/pv_disassembly_mattr.pdf
Old 12-20-2023, 08:31 PM
Just FYI if you are interested,
At high revs (not throttle to be pedantic ) you will have the maximum exhaust port exposed and the port sealed off from the side of cylinder box.
At lower revs (along with lowering the effective exhaust port) this side box opens to disrupte the returning pipe wave, which at low revs is at the wrong time. It is often claimed this box adds volume to the pipe. Strictly it does, but it is not beneficial for that reason. It just needs to be big enough to absorb the wave enough. That way the pipe can be tuned with respect to more top and not suffer a strong mis-timed return wave, or scavenge for that matter.
Old 12-21-2023, 02:42 AM
But those ports left and right are open once the pv is fully openend. Shouldn?t they be closed then? Am I missunderstanding which ports are open or closed? I am generally speaking about the 2 little ports besides the exhaust port in the cylinder that you can see from the inside.
Old 12-21-2023, 04:57 PM
So ports left and right of main exhaust are maximising the port area at full revs.
Try to imagine you want to get the exhaust gas out as quick as possible at top of stroke at full noise.
At lower revs that would promote short ccting.
Brain is full of different systems from previous bikes, but the additional opening to the closed box on side of cylinder should be a low Rev thing.
Tags
power valve
Orientation of oem lowering links? JAD Enduro Suspension 2 11-15-2021 07:06 AM
Powervalve Help 95jersey Enduro Engine - 2 stroke 10 06-17-2015 03:09 PM
PV orientation skraMnoR Enduro Engine - 2 stroke 2 02-23-2013 02:38 PM
Piston orientation noobi Enduro Suspension 5 07-16-2011 01:31 AM
