Old 08-10-2017, 09:35 AM
iflybyu iflybyu is offline
Default 2006 EC300 Dash Wiring
Good Morning,
I am in the middle of refurbing a 2006 EC300. The previous owner tore out all the wiring for some reason, cutting all the plugs out, etc....
I have it all running and charging now. I used the sticky above on getting DC without floating ground and worked great. I have all the lighting functioning now but I am stuck with the cut wiring at the dash. I have figured out the status lighting on the sides of the dash, however the 6 wires coming from the center portion of the dash are another issue....
I have the wiring diagram from the manual but I cannot make out the coding for the dash...There are 6 wires: red, black, blue, yellow, green and brown. Can anyone tell me what they are for?
Thanks
Mike
Old 08-16-2017, 05:42 AM
incase anyone else has this issue...
Red is switched power
Blue ground
Green and black are speedo sensor
White and brown I am still unsure about but must have something to do with tach...
Mike
Old 08-17-2017, 04:00 AM
Caravan Monster's Avatar
Caravan Monster Caravan Monster is offline
Assuming same model in your region. Yellow wrap around ht lead for rpm (doesn't work that well) . If memory serves, I think the capacitor top left powers the blue backlight.
'00 Montesa Cota 315R
'13 Husaberg TE 300
Old 08-17-2017, 07:53 AM
Thank You. Can you make out what the brown wire is power for?
Old 08-18-2017, 02:01 AM
No problem! Brown is clock. It needs to be wired to a 12v battery because it will flatten smaller batteries in a week or two. I fitted a small battery holder to my old ec just to have use of the clock for time cards and did without the rest of the time. Probably a legacy thing from the 4 stroke gassers with starter batteries from that period, only on a gasgas
'13 Husaberg TE 300
Old 08-18-2017, 05:34 AM
Thanks for your time, much appreciated.
Mike
Old 08-18-2017, 05:41 AM
One last question...well maybe one last question... Does the yellow wire pick up its RPM signal from the firing signal to the coil?
Mike
2006 wiring 2stroke Enduro Electrical & Wiring 5 08-18-2016 10:27 PM
2006 ec 250 lights wiring mess 3stepsaheaduk Enduro Electrical & Wiring 1 12-16-2015 11:51 PM
2002 ec300 light wiring and speedo wiring help needed. andy176 Enduro Electrical & Wiring 0 02-04-2014 07:38 AM
2006 EC250/300 Dash silversleeper Enduro Electrical & Wiring 0 12-14-2013 11:31 AM
