Old 12-10-2007, 03:20 AM
Leon_gasgas Leon_gasgas is offline
Default 2007 Ohlins fork EC250 valving
Hi!
I just broke in my new 07 EC250 with Ohlins front and back after my previous 07 was stolen. Has anybody tried to revalve the Ohlins fork (48 EXF) to work better in the tight woods and rocks? Right now (only 4 hours on it) it is punishing me on the rocks. Soon I will change the oil and at the same time I will try the first revalving. I had good results revalving myself (with great help from KTM-Lew) an Ohlins 46. I just wanted to ask first here if somebody has experience with this newer fork so I could save time from testing.
Thank you!
Leon
Old 12-10-2007, 10:36 AM
SpeedyManiac's Avatar
SpeedyManiac SpeedyManiac is offline
I'd send it to Les if you want a revalve. Personally, I added stiffer fork springs (I think they're .43s, shock spring is a 5.6), left the valving stock and am extremely happy with the suspension.
Old 12-10-2007, 11:15 AM
barkeater's Avatar
barkeater barkeater is offline
I agree. LTR is the solution. Send him the forks, riding terrain and your weight (don't lie) and he'll send back forks made in heaven.
Todd A
2003 EC/O 200
Old 12-10-2007, 05:34 PM
GMP's Avatar
GMP GMP is offline
Only problem is he is in Sweden.
Old 12-10-2007, 11:52 PM
barkeater's Avatar
Todd A
2003 EC/O 200
Old 12-11-2007, 01:28 AM
Thank you for the replies! Actualy I live in Finland so Les is a bit faraway. I'll give it a try myself as it is very easy to check the valves. I just hoped if somebody has a baseline with it.
Should I go with bleed shims as per Marzocchi which is magic for the woods and rocks I am driving in, or with smaller pivot shim and larger taper stack (1 stage) as per KTM-Lew for the 46 which worked great as well?
The shock is nice and soft (I am trying to follow the recomendations from the other post about preload... Thanks!) and I haven't noticed any disadvantage compared to the Sachs even though it's missing the high speed adjustability. I haven't touched it yet and it seems ok for my weight and ability.
Best Regards,
Leon
Old 12-11-2007, 07:08 AM
barkeater's Avatar
I bet if you called or e-mailed Les, he'd give up a secret or two.
Todd A
2003 EC/O 200
Old 12-12-2007, 06:01 PM
rippn450 rippn450 is offline
Default suspension
Leon I'd check things like fork oil level in both legs and that the shims match on each side. More than one has come from the factory that weren't assemble properly.
would you mind posting or pm'ing me on how you shimmed your 46's. I have a set that are good in the slow stuff but tend to be a little too soft at race pace. I'm not sure if I should change the mid valve or put more high speed dampening in the base valve.
Thanks
Mike
01 Gas Gas 200XC
07 KTM 310 XCFW
05 Triumph Rocket III
Old 12-13-2007, 02:22 AM
Thank you for your replies!
From your answer and Les (through pm) it seems that the oil height might be incorrect. Actually the fork behaves like my old 46 when by mistake I put too much oil in it (something like 5 cm air gap in one and 7 in the other). I will try the minimum (130mm) air gap and let you know.
The 46 had at the beggining:
3 * 20mm - 0.1
14 - 0.1
18 - 0.1
16
14
12 - 0.2
and finally I was very happy with:
3 * 20 - 0.1
18 - 0.1
16 - 0.1
13 - 0.1
10 - 0.2.
air gap 110mm. I didn't touch anything else. Only the base valve.
Leon
Old 12-13-2007, 06:35 AM
Thanks, if it feels to harsh at 130mm raise it 5mm at a time until it feels better. If that doen't work then valving will be in order.
Mike
01 Gas Gas 200XC
07 KTM 310 XCFW
Ohlins fork bleeders. Porkyblader United Kingdom 0 11-07-2010 12:31 PM
08 EC300 Fork valving AdrenalineJunky Enduro Suspension 9 08-13-2010 03:58 AM
09 EC300R Fork Compression re-valving Keg Enduro Suspension 10 03-29-2009 07:17 PM
Ohlins 46mm valving for use with spiked tire Leon_gasgas Enduro Suspension 1 03-27-2007 05:16 AM
Ohlins Fork ? PEB Enduro Suspension 0 10-06-2006 04:45 PM
