Old 11-21-2017, 04:16 PM
Rampart Rampart is offline
Default polyamide (Nylon 66/polycaprolactam) bushings instead Swingarm & Linkage Bearings
Hi all
my linkage bearings went to a better world
I decided to save a bit on bearings, and go for polyamide bushings. A common thing for ATVs, cars and motorcycles. I'll write here how long they will last.
I paid 13 USD per 100cm polyamide rod (used 15cm) and blank for ruined pin. Still have to buy one screw. Also I paid the workman (a friend of mine) for the manufacture of three bushings and one pin - 8 USD. So budget of repair no more than 25 USD + a lot of stuff just in case.
Old 11-21-2017, 06:28 PM
(F5)'s Avatar
(F5) (F5) is offline
They get a considerable loading on then as they have to pass on the leverage. Think I've tried and failed on a small roadbike in the past. Maybe tried on my old DT or KDX in the past. Have some left over material but can't remember. Too long ago and a bash on the head since.
But simple to try and measure wear/ovalisation. Measure free play wheel off ground. There will always be a little. Write it down and check after a ride. Ride quality will be affected if you bind it up too tight and under load won't ever be as smooth as rolling bearings.
Once bearings are toast however they will be worse and often people don't notice that.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 11-22-2017, 04:49 AM
Leo's Avatar
Leo Leo is offline
Had used Nylon bushings in my DT in the past. (used grease fittings)
Nylon hold well the loads and wear.
But there more drag and suspension sit a bit lower.
If it was me, I would use polyurethane (it's more flexible) for shock bushing. In order to avoid bending stress on shock shaft
Nice test. Post yours results after
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 11-22-2017, 07:51 AM
pscook's Avatar
pscook pscook is offline
A fellow on here sold a kit for the entire rear suspension, I believe it was Synergy Cycles? I'll search. But he used FRP so it would hold up to the demands and wear considerations. I can't tell if your material has any reinforcement, or if it's just plastic.
Phil
(New bike pending...)
Old 11-22-2017, 07:54 AM
pscook's Avatar
Here's the original thread for the bushing kit-=
http://www.gasgasrider.org/forum/sho...light=bushings
Note that it just replaces the roller bearings and seals, you must reuse your sleeve bushings.
Phil
Old 11-22-2017, 09:19 AM
like i said - it's polyamide with graphite filling
Old 11-23-2017, 11:57 AM
pscook's Avatar
Sorry, I didn't see anywhere in your original post that it has graphite in it. While the graphite offer structural support, or is it just for lubrication? Does the graphite carry or distribute the load? I'm not an engineer, so these are honest questions. I'm just trying to learn.
Phil
Old 11-23-2017, 01:30 PM
My mistak, sorry.
As I understand it - graphite for lubrication.
As they say in our sites, it has a coefficient of friction 2-3 times lower compared to polyamide 6. Resistant to impact loads.
This is common, I do not know how to look correctly on your youtube, but in my is looks like this https://www.youtube.com/results?sear...BB%D0%BA%D0%B8
Old 11-23-2017, 01:48 PM
arminhammer arminhammer is offline
http://www.johnstonplastics.com/mech-nylon/
Old 11-27-2017, 07:30 AM
Ooh this is interesting. Can you post the dimensions you made them too please, my linkage etc is due a refurbishment soon and sounds like an interesting project!
2016 RM-Z450
Swingarm & Linkage Bearings Hulle Enduro Suspension 16 11-10-2017 06:16 AM
Swingarm and Linkage Bearings blitz11 Enduro Chassis & Body 34 01-12-2015 03:41 PM
Bearings/Bushings? carlg Enduro Suspension 15 05-19-2014 08:04 AM
