Rekluse Core EXP Install Question
Edit: Had a question about the friction plates, but figured it out.
New issue: My kit didn't come with the set screws . Has this happened to anyone else?
[2003 Gas Gas EC250][http://www.motoadventure.me] Last edited by TavisB; 06-03-2012 at 03:00 PM. |
my set screws were installed already when i pulled it out of the box. I'm sure if you call REkluse they will have them out to you in a day.
2018 XC300 |
Ditto. They will overnight them to you. Rekluse has some of the best customer service on earth.
Also, DON'T FORGET TO TIGHTEN THEM DOWN!!! If the clutch drag increases noticeable shortly after you were in there, stop and look to see that things are tight. One other thing: I couldn't get the gap right with the recommended setup. Always too much clutch drag regardless of how many "ticks" past one turn I went. Installed the light springs (blue ones, as I recall) on both sides and it resulted in perfect engagement.
Newest Spanish Girlfriend: 2011 300 Six Days My Daughter is a U.S. Marine Last edited by andoman; 06-03-2012 at 07:36 PM. Reason: Commented on Recluse custmer service. |
I agree rekluses great customer service. I e-mailed and called one day and had new part in my hand within 24 hours. And I live in northern europe
There is no such thing as bad weather! Only riding gear is improper or insufficient When it hurts you know you're allive! Gas Gas EC 300 Factory Racing 2012 - Ohlins TTX both front and rear - Rekluse Core EXP 2.0 + Rekluse clutch basket - Scalvini full exhaust system - S3 Head - Trusty adjustable PV cover That was ultimate setup for me... Now trying something else for a while... |
Called Rekluse, parts are on the way .
[2003 Gas Gas EC250][http://www.motoadventure.me] |
Fun fun...I got the set screws in no problem. Now I am having an issue with the Rekluse clutch cover. My stock cover is 0.450" where the bolts go through. The Rekluse cover is only 0.360" thick which causes my bolts to bottom out in the case . I've been on the phone with an engineer from Rekluse and they are trying to figure out what is going on.
So my solution is grind down my bolts, get shorter bolts, or use a thicker gasket.
Have a gasket on the way, but I need to get the bike going so I'll be searching for shorter bolts today.
[2003 Gas Gas EC250][http://www.motoadventure.me] Last edited by TavisB; 06-09-2012 at 02:18 PM. |
Don't know what to say about your screws. My lengths were just fine.
Newest Spanish Girlfriend: 2011 300 Six Days My Daughter is a U.S. Marine Last edited by andoman; 06-09-2012 at 05:01 PM. Reason: Added comment about screw length |
This is why some of us have been having bolt length issues. I had the same thing happen, I just used a couple of small washers to make up the depth issue. The stock cover bolt holes are taller compared to the rekluse cover. I'm guessing that some have issues and some do not because of different years and different length bolts being used. May be a consistency thing at the factory? Last edited by desertgasser300; 06-10-2012 at 03:55 PM. Reason: added pics. |
Thread Tools | |
Display Modes | |
Rekluse exp install tips from the guys that know! | nambo-trev | Enduro Engine - 2 stroke | 12 | 08-02-2011 10:19 PM |
Rekluse Core EXP | hasslbri | Enduro Product Reviews | 25 | 06-30-2011 09:53 PM |
Rekluse Core EXP | blanc | General Discussions & Announcements | 13 | 03-01-2011 08:35 PM |
Tech Article : Rekluse Auto Clutch Install | webmaster | Enduro Engine - 2 stroke | 0 | 07-24-2006 10:14 PM |
