Old 09-24-2009, 10:28 AM
SpeedyManiac's Avatar
SpeedyManiac SpeedyManiac is offline
Default Top End Clearances/Specs
Need some quick answers, can't find them anywhere. What are the tolerances for piston/bore clearance? I've heard 0.06mm, but need max/min numbers.
Thanks,
Steve
Old 09-24-2009, 10:35 AM
widebear's Avatar
widebear widebear is offline
Banned
one and a half thou of a inch min, max is up to you but I dont like to run more than .003 inch, two stroke sleds are known to run seven thou on fresh cast pistons.
Old 09-24-2009, 05:02 PM
gasser's Avatar
gasser gasser is offline
Good info on this link (go to the long post) :
http://www.thumpertalk.com/forum/arc.../t-430827.html
I have the official GasGas numbers somewhere I'll see if I can find them. - Ken
Old 09-24-2009, 05:40 PM
gasser's Avatar
This is from the GasGas 2006 shop manual:
Clearance between piston and cylinder:
200 std:0.05mm , limit: 0.10mm
250 std:0.055mm , limit: 0.10mm
300 std:0.06mm , limit: 0.10mm
Ring Gap:
200 std:0.3mm , limit: 0.6mm
250 std:0.4mm , limit: 0.7mm
300 std:0.5mm , limit: 0.8mm
Cylinder Bore:
200 std:62.50mm , limit: 62.60mm
250 std:66.38mm , limit: 66.50mm
300 std:71.99mm , limit: 72.10mm
Old 09-24-2009, 09:53 PM
GMP's Avatar
GMP GMP is offline
Also depends somewhat on what piston were talking about. I'm assuming the now OEM Vertex.
Thread Tools
Display Modes
05 De 300 Specs VORMAN Enduro Electrical & Wiring 9 11-14-2010 06:36 PM
rake and trail specs widebear Enduro Chassis & Body 9 01-28-2009 05:52 PM
ring gap specs jostby Enduro Engine - 2 stroke 9 10-27-2008 06:18 PM
400 fse cam/valve clearances captainslow Enduro Engine 4 stroke (including EFI & Exhaust) 4 05-26-2008 05:19 PM
Torque Specs steve Enduro Engine - 2 stroke 8 02-26-2008 09:30 PM
