Old 04-14-2020, 07:40 AM
Gassi01 Gassi01 is offline
Default Harder spring for Marzocchi 45mm
Hi,
have a problem to get harder springs for a EC125 -10.
The spring is 470mm x 40,6mm.
Is a standard spring for now. I think it is for 75kg.
We need springs for 85kg person plus gear, so 95kg.
Have some one a idee where I can get this?
Live in Sweden.
Thanks / Michel
Old 04-14-2020, 12:35 PM
SS109's Avatar
SS109 SS109 is offline
BetaUSA's online web shop has springs listed for the Shiver 45's. https://shop.betausa.com/p/fork-spring-45mm-marzocchi I'm sure someone on here will be able to help with what spring rate you need.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 04-14-2020, 02:38 PM
rvktm rvktm is offline
k tech uk or s tech Germany or ebay
Old 04-14-2020, 05:14 PM
I found some s tech in Germany
Thanks for your inputs. Michel
Old 04-16-2020, 03:22 PM
i looked on ebay 105 e
Old 04-16-2020, 10:53 PM
Jim_C Jim_C is offline
Originally Posted by Gassi01 View Post
Hi,
Live in Sweden.
Thanks / Michel
Are you aware of the Progressive Floating Piston (PFP) in the top of the forks? The "Zokes" come pretty stiff stock. If you turn the PFP in a few turns and turn in your compression clickers some you might like the feel before re springing.
Just a thought....
Old 04-17-2020, 01:09 AM
Anders's Avatar
Anders Anders is offline
Just a thought....
That is not the case for the 45mm Marzocchi, only the 48mm PFP fork on later bikes
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 05-06-2021, 03:01 PM
maxfli11 maxfli11 is offline
You'll note that link only references the 2010-2011 forks.
Old 05-06-2021, 05:28 PM
SS109's Avatar
Yeah, 2010-2011 Beta RR and RS models. They will fit any 45mm Shiver fork.
'11 EC250R
'98 KDX220
Thread Tools
Display Modes
Marzocchi 45mm settings Russmann Enduro Suspension 7 06-01-2020 09:01 AM
Marzocchi 45mm Forks mcnut Parts 9 01-12-2016 10:23 AM
marzocchi 45mm shiver johall865 Enduro Suspension 0 12-28-2014 06:55 PM
ec300 marzocchi 45mm kingsizerizla Enduro Suspension 7 01-30-2014 10:51 AM
Marzocchi 45mm bushes iancp5 Enduro Suspension 0 02-25-2008 02:49 AM
