Old 01-22-2014, 04:20 PM
kingsizerizla kingsizerizla is offline
Default 1999 ec300 marzocchi 45mm
Hi, anyone know the air gap and oil cc for a 1999 EC 300 ,right way up marzocchi's
Thanks
Old 01-23-2014, 04:44 PM
gassergrant gassergrant is offline
Is there anything on gas gas spain websites in manuals
03 ec300
honda cr500 94
Old 01-23-2014, 04:54 PM
GasGasDreamer's Avatar
GasGasDreamer GasGasDreamer is offline
Thanks
isn't it like 610cc per leg and air is adjustable from 90mm-120mm?
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
2014 Beta Evo Factory 300
Old 01-23-2014, 05:18 PM
Cheers, I found an air gap setting of 135mm, s'pose i'll find out how much fluid that equates to Hard to find any specs on the early gassers
Old 01-26-2014, 02:56 PM
Default Help
Help, changed seal and oil and filled to 135mm air gap. cannot bleed out forks Raised and lowered fork tube through its stroke, no noticeable air. raised and lowered damping rod through its stroke, but only getting resistance, ie damping on the very bottom of the stroke, say last two inches. Here you can feel the resistance and oil spews from the top of the damping rod, but not through the entire stroke.
Has anyone else come across this problem, or has anyone any idea as to what I may be doing wrong??
It should be a straight forward task.
IT,s a 99 ec300 with right way up forks. Thanks in advance to any techies that can put me right
Old 01-27-2014, 09:55 PM
CACTUSREID CACTUSREID is offline
try putting your palm over the open fork leg and pushing it through the stroke to pressure-ize the oil into the internals of the fork .just a thought to try and help.
Old 01-28-2014, 04:57 PM
Thanks. I had tried that. I've come to the conclusion that this may be correct. There are no air bubbles when I move the damper rod or the outer fork. I removed the leg and top cap and spring again, emptied the oil, then refilled through the hole in the damper rod, and went through the bleeding process again. There's only resistance in the bottom two inches of damper rod stroke and that is when oil spews out of the top of the damper rod. I can draw oil to the top of the rod by covering the hole on the up stroke the pushing down, then drawing up again with the hole covered. A couple of these and the rod is full of oil, but drains away again as soon as the vacuum is released, IE I remove my finger, I suppose that is liquid finding its own level. I can only assume that with the end cap fitted oil will draw up the rod of its own accord with the motion of the fork. There is no damping rod attached to the adjuster/end cap, but it seems that it contains some kind of valve for adjustment and is not pushing a rod to adjust a valve at the bottom of the cartridge. If anybody knows this type of fork maybe they can put me right
Old 01-30-2014, 10:51 AM
slocalspode's Avatar
slocalspode slocalspode is offline
PM sent. I have a .pdf file for the users manual of the 45/50 Magnum
forks. It's 2.1mb and willing to send it to anyone that would like it.
Jeff
wtb marzocchi shiver 45mm mbogage "Wanted to Buy" & "Want To Trade" 7 04-06-2014 09:46 AM
wtb marzocchi shiver 45mm mbogage Parts 1 01-12-2014 09:21 PM
in need of some 45mm marzocchi shivers astout93v General Discussions & Announcements 0 06-23-2011 06:41 PM
