Old 09-03-2012, 10:09 PM
Jkosmo Jkosmo is offline
Default Replacing 45mm Marzocchi seals, fork service manual?
My fork seals just started leaking on my 08' EC250, in looking around the internet I could only find broken links to marzocchi service manuals.
Does anyone have access or know where I could find the service manual for these forks?
Also what fork seals have a good reputation? Should I just stick it out and go OEM or is there a good aftermarket alternative?
Old 09-03-2012, 11:30 PM
bergerhag's Avatar
http://www.marzocchi.co.uk/documents...hiver45USD.pdf
http://www.scottysdirtbikespares.com...k-service.html
Old 09-04-2012, 07:26 AM
Awesome links! Thanks!
As for the seals, what have you guys been going with?
Old 09-04-2012, 08:35 AM
MxPhlipper MxPhlipper is offline
Have you tried that risk racing fork seal cleaner yet? Have heard great things about it, am gonna order 1 here in a couple weeks
Old 09-04-2012, 09:41 AM
Interesting. Might have to pick one of those up for future preventative maintenance. Although this time around I'm going to go ahead and do the fork service as I bought it used and want to make sure bushings are good and reset the oil height.
Old 09-04-2012, 09:47 AM
I have been pretty impressed with the synergyseals (.com). They taks a bit to wear in, but for the first time ever i am finding that there is no (noticeable) air buildup in the forks when i remove the bleed screws
Old 09-04-2012, 09:56 AM
Everyone should get the Risk Racing Seal Doctor, it will eventually save a ride/race day for you. You may indeed need seals but there is a good chance that the problem could be fixed with this tool. My '07 leaked bad enough to leave a spot on the floor, and a few seconds with this tool fixed it. I use it to clean the wipers on my '12 48s after a muddy ride as well.
Old 09-04-2012, 11:14 AM
Thanks for the heads up on synergy seals. Going to pick up a set of their flex-seals and lower guide bushings if I don't find any better alternatives.
Definitely going to pick up the seal doctor too.
Old 09-04-2012, 12:47 PM
Another heads-up on the synergy flex seals is make sure you put up a warning sign because until you know how to install them there will be a lot of cursing going on in your garage! They should actually carry a PG rating for first timers!
Think there are some YouTube vids on them to help you through
Old 09-04-2012, 12:49 PM
09 EC 300 service manual kevinlowney General Discussions & Announcements 1 06-27-2012 01:27 AM
Service manual on cd ???Anyone buy one?Review? Stoby Enduro Product Reviews 12 05-04-2011 07:39 AM
Marzocchi 45mm Shiver manual super_rat Enduro Suspension 1 01-01-2009 10:24 PM
service manual skid jackson Enduro Engine - 2 stroke 5 05-04-2008 08:11 PM
