Hi All,
Apologise if this has already been covered - I scrolled through 20 odd pages and could not find what i needed. Basically, I've got a 2000 250 EC, no lights, no voltage regulator etc.. just a bare bike. I've ordered the bits i need to put her right, but has anyone any Photo's of where things go, haven't a clue where the regulator should be fitted etc. Any Photo's would help Thanks in advance A |
Also, when I'm measuring AC volts between the Yellow and Red from the stator i get good voltage. But if i measure from either to earth i get nothing? Any advice?
Thanks |
Wiring diagrams are in the manuals. There are only parts diagrams for the 2000 model, but assuming you have the kokusan 2k3 (big flywheel, wires exit the case at 2 o'clock), the wiring diagrams from later models would be fine.
Gas Gas Manuals For basic lights and a horn, there is something to be said for making up your own lighting loom. MattR did a write up: here Not sure how much Gas Gas would charge for a wiring loom. If you are in the UK, pro racing does lighting kits for enduro bikes: proracing
'00 Montesa Cota 315R '13 Husaberg TE 300 |
Hi,
Thanks for the reply. Looking at mine, i have the 2k 2 stator as they exit at 10 o'clock. I found 3 wires, 2 yellow, 1 orange. When i measure i find one producing 12vac and the other producing 17vac at tick over? Does this mean the orange is earth, if so, can it share the same as the DC earth? If so, which do i use, the 12vac wire or 17vac wire? Thanks A |
Not sure, I'm not familiar with the 2k2. They were more prevalent with the older gasers sold in the US, rare in Europe. The 2k3 lighting runs off the yellow wire that grounds to the frame. There is also a white wire from the lighting coils, which is not normally used. Everything else goes to the ignition. I think the regulator would go on the same tab as the spark plug coil, it does on the later bikes.
A wiring diagram for 2k2 lighting would be helpful (some ktms, huskies and tms will also have used the same set up, if you can't find a GG one) Maybe someone with experience of the 2k2 bikes will chime in.
Gas Gas now sorted. Thanks Caravan Monster for getting back to me.
Hey all, i have been looking at wiring diagrams but mine doesnt seem to match...I have an 01 EC250 that had all lights taken off.
I am trying to wire up a kill switch, as it does not have one. Wires i have are: 2 purple or violet colored wires a Yellow wire a Yellow w/ green stripe wire a yellow and a white wire that go to a connector together anyone know this answer? |
2006 to 2000 | Rabbitist | Enduro Engine - 2 stroke | 1 | 09-21-2011 08:34 AM |
2000 ec 250 | Rabbitist | Enduro Suspension | 3 | 09-15-2011 09:13 PM |
