Old 07-25-2009, 03:50 AM
stay_upright's Avatar
stay_upright stay_upright is offline
Default How easilt can you feel play in the top or bottom end bearings?
easilY sorry and can't edit that bit
Piston is off, I'm trying to check if I can feel play in the big or little end, when pulling/pushing the wrist pin or conrod to try and feel for play the problem is if the pin or conrod is tilted/angled slightly it feels as if there is play and it's difficult to keep everything in a perfectly straight line when feeling for play. If the bearings are loose and there's a problem is it easy to feel - i.e. should be very obvious?
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 07-25-2009, 12:02 PM
gasgasman's Avatar
You should have 0 up and down movement.
Some side to side is normal.
Old 07-26-2009, 04:26 PM
iajim iajim is offline
When you check for up and down movement, grab the con rod as close to the crank pin as possible, don't use the small end(piston pin). Also, you may want a few other people to see if they can detect any movement.
suspension poping noise and feel? GASGAS300HP Enduro Suspension 3 02-13-2010 01:34 PM
Little play in the snow in UK. Todd5774 Ride Reports 5 01-07-2010 11:55 AM
Rod bearing play??? moto9 General Discussions & Announcements 7 12-21-2009 07:52 PM
Play riding with JW Berkyboy Pictures & Videos 1 06-15-2009 04:00 PM
Front sprocket play? Link Enduro Chassis & Body 2 11-04-2007 10:03 AM
