Old 02-13-2010, 07:26 AM
GASGAS300HP GASGAS300HP is offline
Default suspension poping noise and feel?
I've got a almost brand new 2003 Gas Gas Wild 300 Hp ( ATV ) I had it out last Sunday and noticed a slight pinging feeling in my handlebars. I thought maybe something had come loose as it felt to be the front suspension.
Today I lifted it up and checked it out. I noticed my front right shock is making a poping when it decompresses it pops when it is fully extended? The left side does not do this. Any suggestions on this? I'm wondering if the shock is bad and I'm kind of clueless? Thanks in advance.
Shane 918 630-1533
Old 02-13-2010, 10:10 AM
moto9's Avatar
moto9 moto9 is offline
Could be that the shock is under filled, when it compresses it sucks down the seal head...when the shock rebounds it pops back into place.
Does the shock have a resevior, if so, it might have lost it's nitrogen pressure causing the same effect.
Just a theory though.
Check the A-arm linkage, to make sure everything is tight?
If that's all tight, time to remove the shock, pull off the spring and investigate what might be happening.
Old 02-13-2010, 12:53 PM
Default The shocks are ohlins gold series
With a resorvior. How do I refill those if they are out of nitrogen? Is this expensive? Thanks for the help!
Old 02-13-2010, 01:34 PM
webmaster's Avatar
webmaster webmaster is offline
Administrator
It might be the shock bushing. This is an ohlins shock? Right?
You can call Les at LT-Racing to get advice. www.lt-racing.com
Webmaster
GasGas Riders Club
Getting trials bike clutch feel on an enduro bike? SpeedyManiac Enduro Chassis & Body 3 12-01-2010 02:11 PM
knocking noise stay_upright Enduro Engine - 2 stroke 7 08-06-2009 03:30 PM
How easilt can you feel play in the top or bottom end bearings? stay_upright Enduro Engine - 2 stroke 2 07-26-2009 04:26 PM
Top end noise ? Link Enduro Engine - 2 stroke 7 01-17-2008 03:33 PM
Bad Noise roostafish General Discussions & Announcements 17 01-10-2008 08:30 AM
