hole in engine?????
just dropped the gear oil on the ec250, a 09.....
inbetween the gear drain bolt and the crank drain bolt, i have found a drilled hole that appears to be tapped, approx 6mm but maybe a fine thread or somthing as a standard m6 wont quite go in.... WHAT is this hole? where does it go? should it have a bolt in it? bike is running great, no oil leaking or anything, just dont want dirt and water getting into my engine. |
wheeew, thats ok then....
was worried for a second.... |
Oil in the hole. | boyscout | General Discussions & Announcements | 21 | 07-21-2011 03:08 PM |
Small hole in bottom of engine ??? | vgstef | Enduro Engine - 2 stroke | 1 | 01-17-2011 03:17 PM |
Case hole? | Neil E. | Enduro Engine - 2 stroke | 4 | 11-29-2010 10:16 AM |
M6 hole under engine? | moff747 | Enduro Engine - 2 stroke | 2 | 03-19-2008 10:48 PM |
07 GG300EC - small hole at btm. of engine? | g dirt | Enduro Engine - 2 stroke | 4 | 02-26-2008 05:48 AM |
