How to adust rebound
I own a '11 GG300 6 Days (Marzocchi Forks, Ohlin 888 rear shock). The forks have been re-valved by LTR and the Ohlin shock is stock. I'm a 170 lb 50 y/o B rider and I'm not loving life with my suspension set up. The rear end seems to kick me around a lot and this may be confusing my impression of the front fork adjustments. My current set up is:
Shock 9mm spring pre-load on the rear shock Rebound = 25 clicks open Low Comp = 20 clicks open High Comp = 1.5 turns open Fork Comp = 16 open Rebound = 10 open After reading some suspension tuning threads I think I might need to set my rebound properly before I tune anything else and I need suggestions on how to do this (front and rear). I'm planning to soften the compression first so I can focus on the rebound. Any suggestions on what I should do or look for? Thanks, Steve |
The best way to test suspension iv found, is to find a section of track somewhere that you can ride over and over again, to compare the changes.
The rebound adjuster on the zokes is in the top of the fork, compression on the bottom. For the shock, the rebound is the screw on the rhs at the bottom, obscured some what by the linkage, compression are the 2 knobs on the top rhs of the shock body, outer knob is high speed compression, inner screw is low speed. If the shock is kicking up, turn the rebound on the shock clockwise to slow down the rebound (for the record, counter clockwise speeds up the rebound) Ideally you want the shock to rebound enough to keep it up in the stroke but not so fast that it kicks up. Compression is basically how fast the shock will compress, more click clockwise makes the shock harder to move. Forks work on the same principle, only they need to have the same settings on each side, so they don't try and fight each other. I would ride the bike over varying terrain and see what its doing, then change ONE thing at a time, then ride the bike and see if its better or worse. It helps to write down changes and how each suspension setting changes the ride. Its not hard to do, it just takes time. |
Noobi, Thanks for taking the time to write a nice tutorial. I know some of the basics of suspension systems but I don't know specifically how to test and adjust the clickers. For example, I have no idea how to tell the difference between a shock that is using the stroke versus one that is kicking me up. I'm hoping people will be able to describe how to tell the difference between these traits so that I can zero in on the adjustments more quickly. I purchased the Race Tech Suspension Bible book and it only has 12 pages (out of 250) devoted to tuning and they are the least informative pages in the whole book. Most articles I've read about suspension tuning lack simple descriptions and test procedures for iterating on the clickers. What is most needed is a clear description of what each shortcoming feels or behaves like, so that the tuner can identify the trait and correct it. The lack of an informative description of packing, pogo-ing, bottoming, harshness, etc.. results in endless confusion in the tuning process. In the past, I've used the same set of trails for repeated runs as I change the clickers. This has been important in limiting the number of variables in the test. Now I need to know what to look for and in what order to tune things. My baseline plan is to start off with everything at the maximum soft setting. I will then run the rebound up and down (rear then front) to gauge the effect and hopefully find some nominal settings. Then I plan to repeat this procedure with the low speed compression (rear then front). I have no idea what to do with the high speed compression on the rear shock. Thanks, Steve |
My preferred method is to find a gnarly set of whoops and an approach to a corner with nasty braking bumps. I start with the clickers in the middle of the adjustment and ride the section over several times and then change one adjustment 4 clicks and ride the same section several times again. I can't tell one click adjustments but if you go 4 it will either get better or worse and then you know if your going in the right direction. In the whoop section I'm trying the achieve a front to rear balance that doesn't let the front dive and keeps the rear in contact with the ground without kicking. On braking bumps I'm looking for the tire to stay in contact as much as possible without kicking too bad. Once you have it in the neighborhood by going four clicks then go back two clicks to find the center of the sweet spot. Most books say to go one click at a time but frankly I could not usually tell the difference and it would take three rides @ one more click just to know if I was going the right way + it will help you learn what each adjustment does to affect how it rides.
Basically if it blows through the stroke increase the compression dampening. If you can't use all of the stroke decrease the compression dampening. If it kicks back like a pogo increase the rebound. If it packs down and after the third braking bump the tire is skipping you decrease the rebound dampening. Try to set it so that you use all of the suspension in the sever situations. |
forks: put a zip-tie on the tubs, see where it ends up after riding though some of the rougher bits, if it is all the way at the bottom, maybe add a click of compression damping, if it is still up high dial some out so that you are using the full stroke.
shock: it is supposed to be alive but not so much that the rebound will pogo your but up into the air. sometimes it is difficult to tell if it is the initial hit or the rebound bouncing the rear up and that is where like the others said, run the same bit a few times and make changes. Man, when I was 18 none of this mattered, we just rode the snot out of the darn bikes, but that was 35 years ago and I wasn't a pansy like now
Rob Granger / Katy, TX EC300 Breaking more things by 8:00AM than most people break all day. |
Help with Rebound 11 Zokes | Tlineman | Enduro Suspension | 12 | 07-26-2011 04:34 PM |
Rebound dampening ? | BrentMartell | Enduro Suspension | 11 | 03-21-2011 03:46 PM |
Rebound one side only? | chuz | Enduro Suspension | 0 | 09-20-2009 07:15 AM |
43mm WP rebound, help! | rupecopp | Enduro Suspension | 2 | 01-03-2009 11:01 PM |
Rebound adjustment on 04 & 05 MC and EC | FFRDave | Enduro Suspension | 4 | 01-23-2008 10:25 AM |
