Old 05-01-2013, 02:15 PM
olderandyzer's Avatar
olderandyzer olderandyzer is offline
Default Who can rebuild a FSE 450 starter? Video with problem
Went to go ride today and this is what happened. Starter will not engage. Lights didn't dim. Relay ok as I have 12.7 volts to the starter. Took it out after I broke my kickstarter.
Video of starter out of the bike: click on the picture
So there are few parts for this bike. Anyone know what or where I can go for help?
I need a new kickstarter also, preferably a longer one, I can only start the bike sometimes with it, but not today. It broke
Does a DRZ 400 fit by chance??
older and yzer
Old 05-03-2013, 03:13 PM
Just ordered both parts for the bike. Oh well, 450 bucks better spent on the bike than drinking.......
older and yzer
Old 05-05-2013, 08:47 AM
I got home Friday night and took my starter apart. The one brush had corrosion and I cleaned it up so it would make contact with the armature. Cleaned everything up and made sure the brush that was "stuck" moved freely. Put it back together and it started right up!
Looks like water got in there and the small spring that holds the brush against the commutator was frozen. I usually start the bike after washing, but didn't this last time.
I also use a 3000 psi steam genny, so that isn't going to happen again. I see where the starter and the electrics for that matter, could leak some water. I am going to modify this design somewhat. I think the electrics are going to get a liberal dose of some RTV sealant around the plastic housing of the electrics, and on the starter. After 10 years , 8 sitting, the black seals/gaskets/O-rings have become weak on the starter. The positive terminal on the starter looked to be the main culprit though. That is where the brushes are.
Called Go Fasters, and the guy removed the e-start from my order. I still needed the kicker, so that is coming.
older and yzer
Old 05-05-2013, 10:01 AM
cal_tony cal_tony is offline
DRZ kickstart lever does not fit. The tooth pattern is different. Last time I looked at it I thought that using the piece with the teeth from the GG and another longer lever might work.
Since you are going to get another lever, You might want to see if the later model GGs had a longer lever. When I looked at the video on UTUBE of the guy showing how easy it was to kickstart his late model GG I specifically looked to see how long the lever was compared to my 2004 lever. Seemed like it was considerably longer.
Tony
Old 07-29-2013, 09:47 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
The GasGas Pampera 250/280 has a longer kickstarter which is steel instead of aluminum. It works great, and is very sturdy. It also won't wear at the pivot like an aluminum starter will do.
A dealer local to you, GoFasters, or www.trialspartsusa.com should be able to get you one.
Stockers Starters can get you the starter body o-rings.
Good Riding and Wrenching!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 12-20-2014, 10:11 PM
Vinny's Avatar
Vinny Vinny is offline
I'm glad you solved the issue. i have the same problem. I'll open up the starter next week.
Curious; anyone know if the DRZ starter will fit an '05 GG 450 ??
Vinny
Austin , Tx
A wonderfully working and hard riding '05 GG 450.
Old 12-22-2014, 04:23 PM
Ignas Ignas is offline
You can make one starter out of two but drz starter wont be direct swap. I think they spin in different direction.
Can I add a starter? Jeffm Enduro Electrical & Wiring 17 11-09-2013 07:23 PM
starter jet....where and how? mp5 Enduro Intake/Carburetion - 2 stroke 1 05-01-2013 09:13 AM
I bought a 2000 xc and keep finding problem after problem 675AZ Enduro Engine - 2 stroke 12 02-15-2013 07:25 PM
Starter clutch / gear problem iancp5 Enduro Engine 4 stroke (including EFI & Exhaust) 12 01-28-2011 02:45 PM
Another computer problem... choppy video rpduc General Discussions & Announcements 2 03-29-2010 07:13 AM
