Old 02-25-2014, 10:19 AM
Bobt250's Avatar
Bobt250 Bobt250 is offline
Default My starter works great now!
Long winded but I hope worth it,
The back story. My starter never worked very well, especially when cold. It would routinely fail to engage or cut out quickly after barely turning the engine over. It also made lots of clashing gear noises too. The conventional wisdom was that the gears needed more space which seemed to be confirmed by the fact that Gas Gas provided a "fix" in the form of a gasket set that included a thicker gasket albeit it also included a thinner one too. I installed the thicker gasket which seemed to help at first but didn't really. After 2 years of barely working and making lots of clashing noises while attempting to use it the gears gave up. I lost a couple of ring gear teeth and the pinion gear teeth were all rounded off. I did notice that the pinion teeth were rounded off only on the tips which showed that I had the gears pretty far apart so further opening the gap didn't seem to be an option.
I bought a new ring and pinion (bendix) at a cost of $100 for the ring gear and a whopping $200 for the bendix. I installed the new parts with the standard thickness gasket since I didn't like how the shallow tooth engagement ripped the top of the teeth off. The ring gear came with two thin shims which would have tightened the gap between gears so given the conventional wisdom and the fact that there weren't any shims in there stock I left them out.
I had hoped Gas Gas did something to the bendix and that my shiny new one would work better. Nope, it worked worse than ever. After spending so much money only to have it work worse I was pretty pissed. After three rides the teeth stripped off again. That was much worse life than before and I didn't know why. I pretty much gave up hope and decided to kick start it only to have my kickstarter break. Not a happy camper.
I decided I wanted a starter so I set about finding a more fairly priced source for the bendix. I reasoned that the bendix probably was an off the shelf item that fit something else. After much searching I didn't find an exact replecement but I did find a replacement that had all the necessesary parts needed to fix mine. What I found was a bendix from a Honda Elite CH80 scooter is the exact same thing with the exception of the larger gear driven by the starter motor. That gear has more teeth than the Gas Gas bendix but that's the part that never goes bad because it's always fully engaged. I found that you can take apart your bendix and replace all the parts that make a difference and the Honda bendix can be had for $39 all day long on Ebay with free shipping. There are also used ones for cheap which is what I bought since I was experimenting. I bought a used one for $14. The part number is SMU5011.
I also bought a bendix which fits a chinese 50cc scooter, also for experimenting. The reason I bought the 50cc scooter bendix is that it also has 14 teeth on the pinion but more importantly it costs under $15 brand spanking new. If I could make that one work it would be a huge victory. It was not to be as the flyweight assembly is smaller but hey, I'm happy with $39 as opposed to $200 from Gas Gas.
I put the new pinion/flyweight assembly from the Honda CH80 scooter on the Gas Gas gear/shaft. While I was at it I slightly stretched the spring that holds the flyweights in place as was suggested by someone else on this forum. I also used the return spring from the 50cc Chinese scooter because it was a little "lighter" tension spring. If I was going for it I was going all the way. Looking good so far. Next comes assembly on the engine. I took careful measurements by measuring from the teeth of the gears to the gasket surfaces of the cases and it was obvious to me that the spacing was indeed very loose and that even a thinner gasket wouldn't get the gears close enough to prevent the tips from rounding off again. I installed the 2 shims that came with the new ring gear. I still felt like there was going to be excessive spacing between the gears given what my measurements were telling me so I found that I had some washers in my stash that happened to be the exact same inner diameter and were a lot thicker. They are about 1/16" thick and with one of them installed I was where I wanted to be. I was looking for about 1/2mm between the tip of the pinion tooth and the root of the ring gear teeth not counting gasket thickness. I applied a dab of STP to the teeth of the ring gear and put it all together with the thinnest gasket from the Gas Gas kit.
I have to tell you that I was pretty nervous about pushing the starter button. I had high hopes before and was always disappointed. When I pushed the button on a cold engine I was shocked when it engaged immediately, cranked over and over and perhaps best of all it sounded smooth and relatively quiet. Gone were all the clashing noises I had grown accustomed to. I tried it several times and it worked each and every time. It stays engaged for as long as your finger is on the button...every time. I was pumped. I went riding the next day and from the time I rolled it off the the truck in 25 degree weather until I ran the bike after washing it post ride it worked 100% of the time on the first push of the button and without any bad noises. It never worked like this from the time it was new. I can say that I'm in love with my Gas Gas all over again.
In conclusion. #1 Gear spacing is important but opening up the spacing isn't what makes it work well and will only get you stripped/broken teeth. I have a strong opinion that tighter is better particularly for extending the life of the teeth. #2 Should you need a bendix you don't need to spend $200. I spent $14 on the one I ended up using. What really fixed the engagement? Probably stretching the spring as was suggested to me by someone on this forum. Most importantly, what I thought was a bad design actually can be made to work. If you hate your starter you might want to try fixing it. Should you have to? no, but if you want it to work you must fix it. Mine works great.
The broken ring gear on the left. The spacers supplied by Gas Gas, the spacer I used is on the right.
2011 EC300
Old 02-25-2014, 10:37 AM
roverhybrids roverhybrids is offline
could gear marking compound be used to verify engagement, like when setting up the ring and pinion in an axle?
2011 GasGas ec300R
2011 GasGas ec200 Six Days
Old 02-25-2014, 10:42 AM
Bobt250's Avatar
That would be difficult since the bendix would have to be in the engaged position and the tooth would have to be rotated into the root of the ring gear teeth. Difficult but probably not impossible.
More pics:
In the picture with three bendix' the GG is on the left, the Honda is in the middle (with a stripped GG pinion gear on it) and the Chinese scooter one is on the right. You can see what I mean about the teeth being stripped but only at the tips. The return spring, then the flyweight spring that I stretched. The last pic is of the flyweights w/spring
2011 EC300
Old 02-25-2014, 11:49 AM
Clay's Avatar
Clay Clay is offline
Banned
I am constantly amazed at the ingenuity and resourcefulness of the members on this forum!
Old 02-25-2014, 01:47 PM
Brian's Avatar
Brian Brian is offline
Glad you got it working!
Your find of the Honda scooter bendix is going to be very valuable for others.
I got mine working 100% as well. I was fortunate enough to not have to experiment much and I didn't ruin a bendix or anything because of everyone's trial and error in the other thread.
For me to get to 100%, I shimmed the starter out from the case at the mounting bolts (M6 washers?), that way the starter is straight up and down and not pulled in closer to the case by the bolts. Then I stretched the flyweights spring.
2006 Gas Gas EC250
2011 Husaberg FE390
Old 02-25-2014, 03:27 PM
Neil E. Neil E. is offline
Bob,
Your photos show an unusual condition. Your gear engagement was WAY looser than what anyone else has indicated. The pinion has been climbing over the ring gear. Not much wonder it has worn so badly. Obviously there is far more crankshaft location variation than what should happen during assembly. I would expect maybe .010" difference, but your bike must have been off .060" or more.
Factory tolerances need improvement.
While the flyweight spring is the critical setup issue, it can't overcome really poor spacing. For the purpose of a starter, the gear tooth engagement is not terribly fussy. All it needs is from slight play to moderately large play. Yours was grossly excessive.
Excellent work finding alternate sources for lower cost parts.
2011 EC250E
Old 02-25-2014, 04:01 PM
Bobt250's Avatar
There are plenty of variances coming out of the factory. The second bendix that stripped is on the left and shows that engagement was even shallower than when the first gear stripped (middle bendix). Trouble is that when the second one stripped I had a thinner gasket between the cases and the teeth stripped way fast. The only other difference was that I had a different (new) ring gear on the flywheel.
2011 EC300
Old 02-25-2014, 04:56 PM
Novascotiarider Novascotiarider is offline
Great info! could you give me the inside diameter, outside diameter, and thickness of the shim you used? Im experiencing the same troubles. After fixing up my bendix I started wearing my gears as well.
Thanks again!
Old 02-25-2014, 07:23 PM
iamovru's Avatar
iamovru iamovru is offline
Great News! How hard is it to do this fix? I played with my KTM 300 starter a few times and it is pretty straight forward. I have not had the Gasser`s apart yet, but it looks like there is more going on than the KTM`s
15 Beta 300RR Race
Sold KTM 450EXC now moving over to RED! Looks like I found the right bike. Thanks REVERUP!
2011 GasGas EC300 "Stolen By A Scum Bag"
2009 450EXC Sold to Rapid Dog EURO Factory Anti-Hop slipper clutch, GPR V4, Akropovic Full Ti Exhaust, 2013 suspension and wheels.
2009 300XC
2005 525 MXC
2000 WR 400
1996 XR 600
1987 CR500
1990 KX500
Old 02-25-2014, 08:32 PM
Coop's Avatar
Coop Coop is offline
Good to hear Bob. I know it's been acting up a long time. I'm glad you got it all sorted out.
-Mike
2009 Beta Evo 300 4T - 1982 Suzuki PE175
Anybody have an 02/03 450 FSE that actually works ? wakeymatt General Discussions & Announcements 5 08-09-2012 06:07 AM
Does anyone know how the compression release works? stay_upright Enduro Engine - 2 stroke 1 07-24-2009 10:37 AM
04 300 fork kit - Pivot Works bocoz702 Enduro Suspension 2 02-12-2007 08:24 AM
300xc what gearing works best?? Dingoe Enduro Chassis & Body 6 02-05-2007 03:47 PM
