Old 03-19-2014, 05:05 PM
Nick1000 Nick1000 is offline
Default engine will not rev after being driven on low revs
Hi
I purchased a gasgas ec300 2013 some months back. When i have been riding on low revs for some time on singletrack and trials ridning it is struggeling to rev out fully when i come out into the open. it revs but is revs unclean and does not reach maximum revs. after 3-4 runs of ful rev straights it comes back to life. have you got any tips on why this happens? i also have black oil coming out of the back of the silencer. am i running it with to much oil or do i need to set up the carbertor differntly? i am greatful for any help i can get.
Old 03-19-2014, 07:04 PM
n_green n_green is offline
You are way too rich off the bottom. I'd guess you are running standard jetting. The bike will load up with fuel off idle and then be that rich it can't rev out properly. Have a look at the jetting thread and see what others with your bike are running. Spooge has nothing to do with oil ratio so don't worry about that.
Current:
2014 Gas Gas EC300R
_____________________________________________
Previous:
2011 Gas Gas EC300 ELC
2004 KTM 300 EXC
Old 03-20-2014, 01:50 PM
Thanks alot for this information, i will take a look at the jetting thread!
Old 03-20-2014, 02:02 PM
Niall-griffiths's Avatar
Niall-griffiths Niall-griffiths is offline
I have the exact same problem with my bike unless i keep it on the pipe it does this ! and wont clear until i run it hard for a while i have little time to look at it tho but was told it sounded like rich jetting let me know how u get on !
Old 03-20-2014, 03:43 PM
i checked the manual and as i am running in sweden where we have 5-8 degrees celcius right now the recomendation is to tighten the mixture screw. This however enrichens the mixture wich seems to be in the wrong direction. I will however try this at the weekend and will get back with info how it works out.
Old 03-20-2014, 04:55 PM
The stock needle is too rich for the new engines and AS2 carbs. Gas Gas has changed a lot of the bike over the last 10 years but somehow still thinks the same jetting is good enough.
In saying that, even with what I would typically run on my 2010 model, I am finding doesn't quite work on the 2013 even though the engines are setup very similarly. Even running at what I would consider to be quite lean on the needle position I'm getting a bit of spooge although it could just be burning off excess as the last ride where I chugged around a lot I had it dripping from the silencer/pipe join down onto the swingarm. I'ma blame that 4 stroke can! Q stealth spooge trap.
Old 03-20-2014, 06:36 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
Grand jetting master, you need to cut some plugs up and report back, I reckon the new barrel likes it lean. Expectantly waiting.....
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 03-20-2014, 06:59 PM
I think it likes it more like a ktm. Leaner pilot, leaner diameter, richer on the clip pos, and then leaner main. Thats my thoughts. Been hard to test too though as its been sloppy so lots of sustained low rpm chasing traction. I have noticed it splutters up in the rpm quite a bit in the lower gears with even the 175 main, but it could be water being pulled through the filter as well. Hard to test.. but definite spooge city even with 40 N3CW#3 175.. Going half a clip leaner really shows a lack in low end grunt, while closing the airscrew brings bck some of the grunt around 1/8th-1/4 throttle it blubbers down low and won't idle as well an is not as crisp as I like. I'm thinking of moving to a leaner diameter needle in the same position, same pilot and dropping the main one more.
Old 03-20-2014, 07:45 PM
gasser's Avatar
gasser gasser is offline
Cold weather and a motor that doesn't run at regular operating temp because you are lugging it a lot. Before you change your jetting drastically change your premix oil if you are using one with a high flashpoint (above 100C or 212F). I don't know about oils available in your country but here are some in the USA.
Amsoil Intercepter, Amsoil Dominator - both good
Amsoil Saber - bad
Motul 710 - good , Motul 800 - bad
Champion WP2 - good
Old 03-20-2014, 07:52 PM
Gasser, I'm using Amsoil Dominator at 50:1. Other bike runs clean on the same fuels and oils.
Engine won't run at high revs motopsycho87 Enduro Engine - 2 stroke 36 08-28-2013 04:37 PM
Peddle Driven desertgasser300 General Discussions & Announcements 14 04-29-2013 11:57 PM
New 2010 EC300 Engine Noise (falling revs) Jakobi Enduro Engine - 2 stroke 11 11-16-2010 06:41 PM
Max revs when starting up. Todd5774 Enduro Intake/Carburetion - 2 stroke 4 01-24-2010 08:22 AM
L@@king for a 200 Primary Driven Gear set Berkyboy General Discussions & Announcements 2 03-10-2007 09:07 AM
