I chopped my Q-Stealth
The little internal spigot thing that attaches to the back/inside of the tip was rattling in the cone (two mini spot welds broke).
In a pique, I decided to tear it down and fix it. Then I said, "Screw it. Let's cut this thing." I did some rough measurements and decided on cutting 4-inches off the back end using a compound miter saw. For you Euro guys, 4-inches is the same distance as from the left side of the caps lock key and the right side of the F key on your 2006 MacBook Pro 17. That's like about 100 millimeters. I put it all together, and while I didn't kick it to life, I suspect that a dyno would find a bit more bottom, a tad more top, and about 1db less on a standard sound test. |
Here's what the innards looked like, pre-cut.
Not my photo. |
That looks great!
I cut mine down last year and took about 5" out of it. Plus I cut back the little internal baffle a bit as well. I Was playing with jetting at the same time so I didn't really get a back to back comparison but I think it made a pretty good difference all over. I even ordered new decals for it from FMF.
2013 GasGas XC300E 2005 YZ290 1973 Honda CB175 1997 KX60 1983 Yami Tri-Zinger 1984 Suzuki Alt 50 1969 Trail 90 1971 Trail 90 1972 Trail 90 |
I was tempted to go stubbier than 4-inches but I kind of liked the aesthetic of having the cone being set back from the rear mounting tab.
I love science. |
I cut 4.750" off of mine and then re-welded the spark arrestor and baffles back together. I honestly don't think it is any louder than stock and no more spooge!2015-03-21 13.52.53 (800x533).jpg
2011 300 Six Days Plated-Gnarly Pipe Tublis-Pivot pegs-P3 guard Custom billet bits |
I might give this a go, I've seen replacement q stealth stickers on eBay
I chopped mine right back. Fat jetting will still create spooge, but not as bad as stock.
Are you leaving the spark arrestor in place or omitting? I dropped mine. I don't notice it being overly loud. |
I ordered my replacement stickers straight from FMF. They are on their site.
I kept the Turbine core but left the spigot removed.
I took a short spin on it last night. Sounds different. Kinda weird sounding. |
Good or bad? |
Q - Stealth | seb421 | Enduro Engine - 2 stroke | 4 | 07-01-2014 11:25 AM |
Chopped banana exhaust | swazi_matt | Enduro Engine - 2 stroke | 11 | 02-15-2014 11:04 AM |
FMF Q STealth | pistol | Parts | 0 | 09-14-2013 08:04 PM |
