Old 01-16-2008, 07:12 PM
Link Link is offline
Default Top end noise ?
On de-aceleration there is a loud rattle type noise I think coming from the cyl. head at first I thought it was the pipe guard or the pipe springs but with the bike on the stand I was holding onto the pipe trying to find the cause of this noise and it's not the pipe. Could it be the power valve ? The bike runs great and sounds fine on the gas this noise only happens after quick shut off of throttle Bike is an 06 EC 250
Thanks
Old 01-16-2008, 08:25 PM
Brian VT Brian VT is offline
It's most likely just the chain slapping on the swingarm slider.
They all do it. It's unnerving but no harm. Many posts here about it.
Old 01-16-2008, 09:31 PM
No, I heard the noise when riding so I but the bike on a stand in neutral and the noise is loud it's not chain slap
Thanks
Old 01-16-2008, 09:52 PM
GMP's Avatar
GMP GMP is offline
The PV will rattle but its normally not excessively loud. If your pipe o-rings are bad (worn from vibration) that can cause vibration noise, did on my '07.
Remove the right side PV cover and run the bike. See if the actuator plate is vibrating against the stop bolt when you hear the noise. The plate shoud touch this bolt with very slight preload with the engine off.
Old 01-17-2008, 11:58 AM
I just replaced the O-rings but I think there too small as it's leaking at the pipe connection so I will sort that out today & try your suggestion. Maybe the rattle I'm hearing is normal. I have never owned a 2 stroke with a PV
Thanks
Old 01-17-2008, 12:22 PM
GMP's Avatar
GMP GMP is offline
When you remove the pipe, look at the edge of the header connection for wear marks that indicate it was vibrating against the spigot bolts. Thats what happened to mine. It was very loud, but difficult to see. Use the correct o-ring.
Old 01-17-2008, 12:43 PM
You'll need to grind an allen wrench shorter to access the bolt(s) without taking the pipe off.
Old 01-17-2008, 03:33 PM
FIXED....I went to the auto parts store & used 44X4 O-rings it was a real tight fit I had to smack the pipe with a rubber mallet a few times to get er on but the noise is gone!! now there is only a faint rattle of the PV that GMP mentioned. Thanks again for the help.
Engine noise roostafish General Discussions & Announcements 11 11-24-2009 12:01 PM
clacking noise getndirty Enduro Engine - 2 stroke 11 09-26-2009 07:54 AM
clutch noise? LAWMAN Enduro Engine - 2 stroke 9 01-16-2008 08:15 AM
Bad Noise roostafish General Discussions & Announcements 17 01-10-2008 08:30 AM
Exhaust noise captainslow Enduro Engine 4 stroke (including EFI & Exhaust) 1 12-10-2007 07:26 PM
