Old 01-03-2016, 02:34 PM
erikkihl erikkihl is offline
Default EC 300 Racing 2014 Stator problems
Hi,
I have searched the forum but couldnt find any answers.
I think that my stator is broken. The lights on the bike doesnt work but the bike runs good. I have 0V on the yellow and brown cable at the rectifier. If I ohm measure between thoose 2 cables i get 1,5ohm.
Is the stator burned? What should the Ohm be between the cables?
Can I put the Kokusan stator on? If so, can I take a stator from KTM? I think i should have the Ducati.
Old 01-03-2016, 04:04 PM
Neil E. Neil E. is offline
The Ducati rotor and stator were only used on the very early GG bikes (when the engines were counterbalanced). I don't know what wiring changes have taken place on the newest bikes, however you should check for AC voltage directly at the stator yellow wire.
You should get a reading of about 13V between the yellow wire and chassis ground with the bike running at a fast idle. If you have power there, then follow through the wires to look for a fault. The most common problem is a broken wire in the headstock area. This happens from the back and forth movement of the handlebars.
I believe a KTM 2T stator can be used if you are willing to change the connections.
2011 EC250E
Old 01-03-2016, 06:17 PM
gasgasman's Avatar
Check with these guys...
http://www.regulatorrectifier.com/ca...ng-Stator-Coil
Old 01-04-2016, 07:08 AM
Zman's Avatar
Zman Zman is offline
You may want to do some research to determine if the older GG units will be a suitable replacement. Here is one of the older units. http://www.ebay.com/itm/Electrosport...pWT~r7&vxp=mtr
Old 01-04-2016, 06:21 PM
Dirt Dud's Avatar
Dirt Dud Dirt Dud is offline
These kind of responses make owning a gasgas a pleasure . You guys with all this knowledge and your quick resolutions make this board the great board that it is . So thank you for that and thank you Jeff for the time and effort you give free of charge .
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES
2013 to 2014 racing ! rubber Jonny Pictures & Videos 4 04-29-2014 01:53 AM
still looking for help on the stator KTMAndy Enduro Electrical & Wiring 9 01-02-2014 12:04 AM
2k3 stator with cdi from 2k2 whodat Enduro Electrical & Wiring 3 07-21-2013 10:34 AM
stator rewinding mountain thumper Enduro Electrical & Wiring 10 09-28-2008 02:26 AM
