Old 04-11-2016, 05:47 PM
rosco's Avatar
rosco rosco is offline
Default 2011 ec125 Six Days [Jetting]
What have you guys been running for jetting on a 2011 ec125. This is a new six days that has a ASII 38mm carb on it. Jetting on it right now is
170 main
40 pilot
n3cw needle 2nd clip position
1.5 air screw
Bike starts and idles good. Takes off and feels good at low rpm. If you get into the throttle it starts to die out real bad like its real lean in the mid. Seems to run good on the top end once you get it there. This is about the same jetting that I have been running in the 250's and 300's with good luck. Does the 125 require totally different jetting?
elevation about 4,000 ft.
air temp=65'F.
Rosco's Motorcycle and ATV
Rapid City, South Dakota
www.roscosmotorcycle.com
Old 04-11-2016, 08:29 PM
john r b's Avatar
john r b john r b is offline
What # slide? #7 i bet
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 04-11-2016, 10:24 PM
Zman's Avatar
Zman Zman is offline
On two of our older 125s we installed KX125 35mm carbs and they work great and are easy to jet.
Old 04-12-2016, 12:25 AM
What happens when you go richer on the clip position?
Old 04-12-2016, 06:38 AM
Zman's Avatar
and yes the 125s have different jetting.
Old 04-12-2016, 12:54 PM
Elvis74 Elvis74 is offline
I run my 125 with the following jetting
Main jet 185 to 195
Pilot jet 48 to 50
Air screw 2 rotation out
Needle NOZI
2. Clip position
Slide no 9
PWK38
All depends on the temperature I'm riding
The small engines requires bigger jets than the bigger ones.
Send from iPhone using Tapatalk
4 strokes are only good for power generators
Old 04-12-2016, 03:27 PM
Smaller capacity, less displacement, results in less signal (or volume of air charge being pulled into the cases for every stroke).. which in turn picks up less fuel and thus requires larger jets .
Old 04-13-2016, 11:51 AM
rosco's Avatar
Thanks guys! Haven't messed with it yet. Just wanted to get some general ideas for a good starting point. I'll let you know what I end up with.
Old 03-18-2017, 09:21 PM
rosco's Avatar
Main jet 185 to 195
Pilot jet 48 to 50
Needle NOZI
2. Clip position
Slide no 9
PWK38
What is your elevation and temperature that you use this jetting? Thanks!
2011 EC125 Six Days parts on E-Bay nknudsen Parts 5 10-17-2014 04:06 PM
EC125 - base line jetting doutsh Enduro Intake/Carburetion - 2 stroke 9 09-08-2014 12:11 PM
Jetting help 2011 six days 300ec Colemanian Enduro Intake/Carburetion - 2 stroke 9 11-14-2012 09:52 PM
2011 125 6 days jetting orangezuk Enduro Intake/Carburetion - 2 stroke 11 04-28-2011 11:09 PM
jetting for ec250 2011 six days taku60 Enduro Intake/Carburetion - 2 stroke 2 02-01-2011 11:01 PM
