Hi,
I notice that my EC 300 2011 was leaking gas when I lean the bike on the side. Sometime even when put it on the kickstand it's start to leaking from one of the hose on the carb. I wondering if I have to adjust the float level to fix it? any idea? Thanks |
If this is a new phenomenon, then I would check my float needle for wear at the tip, debris, or a build-up of deposits on the seat, or replace the float needle.
If this has been going on for a while, or you are unsure, then I would at least check the float height. If this is the trouble, then it is also dumping your fuel on the ground when landing from jumps, and any hard impacts. Good luck! Jim Cook .
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
![]() Quote:
I look at the needle. Everything look fine. The angle part of the needle is a bit darker that the rest of the needle but I thing it's normal. For what I remember, I always had this problem. I played a bit with the float level this afternoon. It's already better. I can lean my bike a bit more on the side before it's start to leak. I wondering until with angle from the ground I could lean the bike whiteout having leaking gas? Cheers |
![]() Quote:
Congratulations on your results. Your fuel mileage should increase, also. I love my 2011. It's a hoot to ride, and one of the best Gassers that I've owned. . My bike has to get to about 45 degrees before it starts peeing fuel out the overflow hose.
![]() Quote:
Thanks again for your advice. ![]() |
How did the test go?
Does it do it when u lean your bike to the other side? If not, it means that your carb isn't set level to the bike.
2011 GasGas EC200 Six Days Edition - $3000 | Hillsy | Used Bikes | 5 | 10-10-2014 05:04 PM |
carb. vent hose check valve | john r b | Enduro Intake/Carburetion - 2 stroke | 5 | 05-15-2014 01:30 PM |
2011 300 blew off radiator hose | Bark3rd | Enduro Engine - 2 stroke | 9 | 01-29-2014 11:47 PM |
2011 F. brake hose guide locations | nknudsen | Enduro Chassis & Body | 3 | 03-28-2013 07:31 AM |
2011 EC250f manual---breather hose question | forgiven | Enduro Engine 4 stroke (including EFI & Exhaust) | 7 | 09-11-2012 05:57 AM |
