Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > GasGas Member Polls
GasGas Member Polls Find out what everyone thinks about it!
View Poll Results: What rear tire width are you using??
140 11 28.21%
130 3 7.69%
120 15 38.46%
110 9 23.08%
100 1 2.56%
Voters: 39. You may not vote on this poll
Old 09-06-2016, 05:51 AM
Zrt1200 Zrt1200 is offline
Default What rear tire width??
What rear tire width are you using on your bike and why If posting. Also please include your engine size.
Old 09-06-2016, 08:13 AM
dANbOT's Avatar
dANbOT dANbOT is offline
Always run a 140 Mich S12 but that's mis-leading since their standard of measuring is way off from other manufacturers. Ive always considered it about a 120.
2014 300
Wider tires feel generally more stable, and allow for lower pressure for me. Only downfall is in deep ruts, a 110 will claw through the rut better.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 09-06-2016, 08:49 AM
phoenix's Avatar
phoenix phoenix is offline
We use a 110 on the 200 and a 120 on the Husaberg 300.
2009 Husqvarna TXC 450
2013 Husaberg TE 300
2014 Gas Gas XC 200
Old 09-10-2016, 10:48 PM
gasgasxc gasgasxc is offline
Uggh.
Not really the info you were looking for?
Tire widths and why.
Lots of variables.Also side wall height is relative to the width and how that equates into traction.Throw air pressure in the mix and traction qualities of a particular tire or tread design add traction availabilty and conditions.
Horsepower and horsepower characteristics-torque or revver or somewhere in the middle?
Ripped fit 165 pounder on a 2502t or fattass on a 300 2t or maybe fattass on a 200 2t
Sandy loam or techncal steep single line slick and rooty trails?
Point is nobody can use a tire size recommendation unless you get the rest of the story.
So what a guy runs means squadoosh to another rider.
Here's some simple parameters.Very basic and vague.
Wheel spin is very important on a 2 stroke.A 4t not as critical but still a factor.
A skinnier tire will hold edges better.A wider tire will sluff off into ruts and blow corners easier.
A skinnier tire will give you less traction and allow the engine to work easier while a wider tire gives more traction and makes the engine work harder.This is a generalization and in this instance do not confuse traction with performance
So assuming you have the right tire to match terrain and conditions with the right amount of traction for the rider weight and horse power characteristics
You should
A. Feel like you can find traction anywhere with ease
A
B.Feel like you can spin the tire at will with a little throttle or throttle and clutch action depending on the gear you are in and the available traction at the time.
In summary you want a tire that gives you maximum traction while being able to easily control tire spin and maintain optimum engine performance.
Hope this helps
Old 06-22-2020, 08:37 AM
RockJunkee's Avatar
RockJunkee RockJunkee is offline
Bridgestone x30 110 . On both of my bikes ktm 450 and an 18 xc 250
Metzeler rear tire hamilton Parts 0 11-05-2015 06:05 PM
Rear tire size for 300? 95jersey General Discussions & Announcements 9 12-30-2014 01:40 AM
rear tire keeps coming off rim peanutsracing1 Enduro Chassis & Body 6 01-31-2011 09:16 AM
Rear tire jostby General Discussions & Announcements 28 07-04-2009 01:17 PM
