Old 11-05-2016, 08:51 PM
gasgasman's Avatar
Default Rekluse Core Manual
This week I installed the Rekluse Core Manual on my bike.
My clutch would squawk really bad under a heavy load.
I did a good shake down run today.
The Rekluse Core Manual completely corrected the noise issue.
Finding neutral is a lot smoother. No clutch drag when the lever is pulled in.
The engagement point is the same as stock.
As you can see in the pics, there's a LOT more oil flow to the clutch plates.
Overall, this is an excellent mod. It is 100% plug and play. No adjustments needed.
The Rekluse comes with: Pressure plate, Inner hub, Steel plates, Springs with bolts and spacers, lock washer ,and throw out bearing.
OEM inner hub. Closed off-no oil flow.
Rekluse- open back shown.
OEM pressure plate- closed off.
Rekluse pressure plate.
Old 11-05-2016, 08:53 PM
gasgasman's Avatar
Thumbs up
Installation complete. Really too pretty to cover up.
Rekluse cover.
Old 11-05-2016, 09:42 PM
Dirt Dud's Avatar
Dirt Dud Dirt Dud is offline
Great looking and they work sweet I have been putting the Recluse Auto clutch in all my enduro bikes . They do need to be adjusted as they wear but that is to be expected . I have not had a manual but I bet it is like the auto clutch , that is really nice . Give it a good beating and see how it holds up .
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES
Old 11-05-2016, 09:51 PM
gasgasman's Avatar
The engine seems to rev a little faster.
Now I see why, there's a lot less rotating mass with the Rekluse.
Old 11-06-2016, 03:54 AM
Dirt Dud's Avatar
Now the big $ question , how much for the manual clutch ?
Rekluse Core EXP 3.0 d251man Parts 5 10-03-2016 06:05 PM
rekluse core manual question?? nambo-trev Enduro Engine - 2 stroke 3 02-15-2014 06:12 PM
Looking for a Rekluse Core EXP myrcrocks "Wanted to Buy" & "Want To Trade" 7 02-03-2014 11:06 AM
rekluse core exp 2.0 leeroybrown9 Parts 0 07-26-2013 03:23 PM
Rekluse Core EXP blanc General Discussions & Announcements 13 03-01-2011 08:35 PM
