Old 01-16-2017, 07:23 AM
risk74 risk74 is offline
Default 2004 EC300 Ohlins Fork Springs
I need to find some heavier springs for my 2004 EC300 with 48mm Ohlins forks, cannot find a supplier or even the dimensions anywhere. I appreciate any help. Thanks.
Old 01-16-2017, 08:36 AM
philm philm is offline
This appears to be the manual for the 48mm forks for the 2005 models at least. It has dimensions listed for the springs.
https://www.ohlins.com/app/uploads/w...M_07295-17.pdf
Have you tried contacting an Ohlins dealer? Are you in the U.S.?
https://www.ohlinsusa.com/ohlins-dealers
Old 01-17-2017, 09:59 AM
Ohlins doesn't even list any springs (part # starting with 02428) for these 48mm forks. I guess I will have to measure them and try to find something comparable from Race Tech.
Old 01-18-2017, 01:25 AM
These are the part numbers and specifications from the manual found at https://www.ohlins.com/app/uploads/w...M_07295-17.pdf
Part numbers-Spring rate: (depending on models)
2428-39: 3.9 N/mm
2428-41: 4.1 N/mm
2428-43: 4.3 N/mm
2428-45: 4.5 N/mm
2428-47: 4.7 N/mm
Fork lengths and diameters
Front fork ?48
?A ?B Length (L)
53.9 mm 59.3 mm 938 mm
Front fork ?46
?A ?B Length (L)
53.9 mm 58.4 mm 938 mm
Rebound and compression adjustment
Refer to mounting instruction for set-up data.
Maximum open rebound and compression valve:
20 clicks.
Free Spring Length:
All forks: 467 mm (service limit 460 mm).
Spring preload:
Maximum allowed adjustment
range 4-8 mm (with optional spring supports).
Old 01-18-2017, 08:52 AM
2428-39: 3.9 N/mm
2428-41: 4.1 N/mm
2428-43: 4.3 N/mm
2428-45: 4.5 N/mm
2428-47: 4.7 N/mm
Front fork ?48
?A ?B Length (L)
Front fork ?46
?A ?B Length (L)
20 clicks.
Free Spring Length:
Spring preload:
Thanks, that's what I found too, but they do not seem to be available from Ohlins any more. I found some comparable springs from Race Tech and have ordered those. The only differences is the free length is 472mm, which will give me 5mm of pre-load, which I think I can live with.
WP Fork Springs & Ohlins Shock Spring Rick "Wanted to Buy" & "Want To Trade" 3 08-08-2013 02:31 PM
