Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Trials Technical Forums > Trials Intake/Carburetion - 2 stroke
Trials Intake/Carburetion - 2 stroke Jetting, Reeds, Air Filters, etc.
Old 01-29-2017, 12:13 PM
funmachines funmachines is offline
Default Strange issue with running lean
I've been trying to solve an issue with my 97 JTX 270 and can't seem to pinpoint it. It runs borderline OK when I just start it and then gets very lean and it's not the carb - I've rebuilt it and it is clean, new float valve, etc. I also replaced the crank seal behind the stator and put in new reeds. It seems to me that there is either some other air leak I need to find or I have a problem with my gas flow from the tank. I'll take off the tank and check that but I don't think that is it as I get plenty of flow out the fuel hose and have replaced the filter I have in line.
Any ideas? Should I seal up the motor and look for leaks?
Thanks
11 Husaberg 570
12 Husky 310
97 Gas Gas JTX 270 trials
10 Beta Evo 290 trials
02 E440 Cannondale plated
Old 01-30-2017, 06:45 PM
SwampGasser SwampGasser is offline
check intake rubber for cracks
Old 01-31-2017, 09:09 AM
cbutler's Avatar
cbutler cbutler is offline
The carb has a filter on it at the fuel inlet have you cleaned it?
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 02-03-2017, 12:53 PM
Thanks for suggestions. I've cleaned and rebuilt the carb completely but did not look at the carb boot closely - I'll check that tomorrow. If that doesn't locate an issue I'll try to pressure and vacuum test the motor.
11 Husaberg 570
12 Husky 310
Old 02-03-2017, 07:09 PM
cbutler's Avatar
Jim Snell would be more than happy to help you he is the former importer for gas gas you can contact him at trialspartsusa.com
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
How to know if the bike is running lean? Munch Enduro Engine - 2 stroke 66 06-30-2021 03:08 PM
Blue/Yellow Wire on ECU/running lean???? Why Z? Enduro Engine 4 stroke (including EFI & Exhaust) 4 10-02-2015 04:22 PM
Strange issue. Need advice. FDB Enduro Intake/Carburetion - 2 stroke 6 07-20-2014 03:04 PM
Steep uphill running issue (F5) Enduro Engine - 2 stroke 8 01-27-2013 04:10 PM
12 300 running strange shark4465 Enduro Engine - 2 stroke 21 01-05-2013 08:20 PM
