Old 11-06-2017, 08:31 AM
Mud-Ectomy's Avatar
Mud-Ectomy Mud-Ectomy is offline
Default 2018 Ec300 Jetting Specs
Does anyone have any solid Jetting specs for the 2018 EC 300
Sea level, Hard Enduro stuff. A wee bit on the rich side ok.
Cheers
2018 EC 300
Old 11-06-2017, 12:05 PM
CDN Rick's Avatar
CDN Rick CDN Rick is offline
Cheers
IIRC I believe all dealers were sent info on this.
Otherwise I'm sure GGNA will have info for you. Try reaching out to them and I'm sure they will have a jetting table or better for you.
2018 GasGas EnduroGP250
2018 GasGas TXT GP300
1994 Honda CR500 (Ice Racer)
Old 11-06-2017, 09:30 PM
Adrian200xc Adrian200xc is offline
I went a clip leaner. It helped a lot. I was going to try a leaner pilot but I got a lectron instead.
Old 12-04-2017, 11:26 AM
Andrea#92's Avatar
Andrea#92 Andrea#92 is offline
Cheers
My 2018 EC 300 here in Italy run very good with N2ZG 2^ 42-178 (0-10 degrees, 200-1000 mt)
GasGas EC 300 2018
GasGas EC 300 2008
GasGas EC 300 2015
GasGas EC 300 2012
GasGas EC 125 2011
GasGas EC 125 2008
www.enduropuro.it
www.youtube.com/user/AndreaGasGas92/videos
Old 12-31-2017, 12:17 AM
chunkysoup's Avatar
chunkysoup chunkysoup is offline
How do you like the Lectron on the 2018? What did it do for the power delivery?
My 18 power comes on way stronger then my 2011...
Old 02-17-2018, 02:15 PM
Keg Keg is offline
NECJ #2
MJ 175
PJ 42
AS 1 1/4
1000ft alt
65 - 85 degrees f.
95-98 octane gas
EC300 2019 (11 Gassers owned, many more to go)
Old 02-17-2018, 09:48 PM
Mud-Ectomy's Avatar
Thanks Keg I will give it a try.
Went out today with
178 Main
45 pilot
#1 standard clip
AS 2turns out
And had a bog off of idle
Thanks for the help
Martin
2018 EC 300
Old 02-19-2018, 09:48 AM
Anyone tried the N3CH needle yet? It worked very good in the previous models. Rode my 18’ for the first time yesterday and the N1EF needle is just awful. Zero bottom end and then explodes into mega power in the mid to top. Makes it nearly unrideable in anything technical
Old 02-19-2018, 11:40 PM
Gasser Nate's Avatar
Originally Posted by memphis2857 View Post
Anyone tried the N3CH needle yet? It worked very good in the previous models. Rode my 18? for the first time yesterday and the N1EF needle is just awful. Zero bottom end and then explodes into mega power in the mid to top. Makes it nearly unrideable in anything technical
I have the N3cj in mine, still slightly spoogy down the pipe running stock jets, 42/175 but sings nicely everywhere else. I?ll throw a 40 pilot in when I can be bothered to clean it right up.
Old 02-20-2018, 03:21 PM
Gottsell Gottsell is offline
Has anyone tried Suzuki needle necj?
In my old yz250x ?16 i run n3ew and n3cw maybe that works for gg300.?
I dont like the stock jetting in my gg300?18 way to rich for level.
Revised Jetting Specs NEDW Jakobi Enduro Intake/Carburetion - 2 stroke 197 09-19-2014 08:17 AM
'06 EC300 stock handlebar specs? brider Enduro Chassis & Body 0 09-16-2013 03:08 PM
What is the stock 200 needle and jetting specs shaheeb Enduro Intake/Carburetion - 2 stroke 3 03-24-2012 10:56 PM
2010 EC300 Factory Jetting Specs - WTF? JP4 Enduro Intake/Carburetion - 2 stroke 197 07-04-2011 11:03 AM
