Old 05-18-2018, 06:29 PM
chunkysoup's Avatar
chunkysoup chunkysoup is offline
Default 2018 swing arm / axle adjuster
My 2018 XC300 did not come with any notches in the swingarm for aligning the axle... anybody else see this on there 2018?
Not the end of the world for me, I still know how to adjust it😉 Just not the attention to detail that I would expect from GG.
2018 GASGAS 300XC
2011 GASGAS 300EC
1981 CR250r
1999 Excelsior Henderson Super X
2003 FZ1
Old 05-18-2018, 06:43 PM
Mine don’t have them either. This isn’t a GG part. It’s pretty obvious that they are getting their frames and swingarms from WP. It seems that some have the marks and some don’t. GG and WP both need to step up their QC. I fixed mine by measuring to make sure the wheel was aligned and then using a dremel tool to make a small notch in the swing arm.
Old 05-19-2018, 06:40 AM
Gasser Nate's Avatar
Mine was the same, pretty pissed of by that, I measured from the swing arm pivot bolt back to the axle to make sure it was square then used a sharp chisel to notch the swing arm.
Old 05-21-2018, 06:32 AM
arminhammer arminhammer is offline
I have never used the notches on any bike. Never found any of them reliable.
Old 05-21-2018, 06:44 AM
pigpen966 pigpen966 is offline
+1 Always use a tape and measure back from swingarm pivot
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 05-21-2018, 06:47 AM
gasgasman's Avatar
Same here.
I just look down the chain from the rear and see if the sprockets are in line.
Pfp adjuster Cox76y Enduro Suspension 5 04-28-2016 08:29 AM
PFP adjuster gasgasman Enduro Product Announcements 5 07-12-2015 06:10 PM
Need Front Axle & Axle Nut estwudsracer Enduro Chassis & Body 1 09-11-2013 12:23 PM
Main Jet Motorcycles Enduro Axle Nut/Wrench/Axle Pull HydroDog Enduro Product Reviews 2 09-24-2009 12:12 AM
