Old 01-19-2020, 04:32 PM
3DKevin 3DKevin is offline
Default 2014 EC300 Supermoto Conversions
Just picked up this 2014 EC300 a couple days ago. I've wanted to build a street legal 2T to mess around with for awhile now; I was originally planning on going with a KTM or husky, but this deal was too good to turn down. Questions I have:
1.) Has anyone here done a supermoto conversion on this specific year/model?
2.) I know a 4.25" rim with a 140 will fit, is it possible to squeeze in a 5" rim with a 150?
3.) I've seen mentioned in some threads that husky wheelsets are identical to GasGas. For what years is this true?
4.) Gearing recommendations for street riding?
I know this bike will be extremely impractical, but it's a project idea I've had for quite some time. Any feedback or advice is appreciated, thanks!
Old 01-20-2020, 01:48 AM
(F5)'s Avatar
(F5) (F5) is offline
Tyre choice will be critical. Erm. . . Maybe spikes?
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 01-20-2020, 02:08 AM
Anders's Avatar
Anders Anders is offline
1. My son did something similar to his 08 or 09 model. Although the 14 has a different frame and forks, things regarding wheels and brakes are quite similar.
2. I think he used a 4.5" rim with a 150/70 BT090 tire. I wouldn't use a 150/70 tire on a 5" rim.
3. I don't know about that, but in case it is true, it would be the italian huskys. I know they use the same rear sprocket, but I don't know about the rest. Motocrosscenter sells complete SM kits, https://www.motocrosscenter.com/shop...bs-196601.html.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 01-20-2020, 07:27 AM
Thank you for the info. I made a typo in my original post; I plan on running either a 140/150 on a 4.25", or a 160 on a 5".
Old 01-20-2020, 07:54 AM
Anders's Avatar
I don't think a 160 will fit. I can measure it; as I have a '15 Gasgas and my Supermono with a 5" rear and a 160/60 BT090.
However, it will take some days before I can get it done.
On the other hand; the link I gave you from Motocrosscenter states that their kit has a 160/60 on a 4.25"
Anders
1986 Duc Mille S2
etc
Old 01-20-2020, 07:58 AM
Anders's Avatar
My son Fredrik's EC300SM
Anders
1986 Duc Mille S2
etc
Old 01-20-2020, 09:26 AM
gasser's Avatar
gasser gasser is offline
Here is a rear 42 tooth rear sprocket that will fit a GasGas hub. 1991 Suzuki dualsport DR250S will fit. Only the "S" model - the regular DR250 is different.
https://www.rockymountainatvmc.com/p...ocket-p?v=2578
Old 01-23-2020, 04:18 PM
I appreciate it. Let me know how that measurement works out... in the mean time, I reached out to Warp9 to see what hubs they use for their GG sumo kit. They said they use a pre-2012 Honda CRF hub on the rear and a KTM up front. I've never seen anywhere on this forum about Honda/GG rear hub crossover compatibility, so now I'm even more confused.
I would just buy the Warp9 kit and call it a day, but I'm dying to run Alpina wheels, which is why I'm looking for a crossover and curious if the 5" will clear with a 160.
Old 01-24-2020, 01:46 AM
Anders's Avatar
I hope I can do the measuremenst over the weekend.
Well, up front you can get away with almost anything. It's just a matter of lining up the disk in the caliper and making some spacers to fit, as long as you find suitable bearings. I (and plenty others) have fitted a GG hub in Yamaha forks, for instance.
Its the rear that represents the problem, as both the chain line and the brakes must fit, while the wheel is still in the centerline of the bike.
People have also used cast street bike wheels from e.g. Aprilia RS125 and I think also Suzuki GS500 if memory serves me right.
I have never built a SM bike, but I did install magnesium PVM Ducati wheels on my Bimota Supermono. Then I had to spend some hours in the lathe and milling machine...
I have never heard of Alpina before, but they look nice.
What part of the world are you in?
Anders
1986 Duc Mille S2
etc
Old 01-24-2020, 08:26 AM
pscook's Avatar
pscook pscook is offline
I don't believe that the CRF and GG hub "crossover," per se; rather that they likely have similar rotor to sprocket spacing and any offset will be factored into the lacing process. As long as your rotor and sprocket spacing is reasonably close to original, you can make up any tolerances with custom spacers and the sliding caliper on the brake side.
Phil
(New bike pending...)
Tags
ec300, husky, husqvarna, sumo, supermoto
EC300 Supermoto conversion motopsycho87 Enduro Chassis & Body 24 02-27-2017 10:36 AM
ec300 coversion to supermoto adickted United Kingdom 6 03-24-2010 07:48 PM
Marchesini Supermoto Rims for EC300 cheekeon Enduro Chassis & Body 1 04-17-2009 09:25 AM
Gas Gas EC300 2001 Supermoto maybe johns2394 Enduro Chassis & Body 12 01-29-2009 07:58 AM
