Old 12-20-2020, 05:13 AM
Tigger996 Tigger996 is offline
Default ec450 & 400
Hi
I am new to the group and I am in the process of building a couple of Supermonos using anEC450FSE and a 400. There are a couple of things I need to know. Is the ignition wasted spark and would a 16x18 clutch master cylinder be OK. Thanks Terry
Old 12-21-2020, 02:07 AM
Anders's Avatar
Anders Anders is online now
Originally Posted by Tigger996 View Post
Hi
Terry,
As I mentioned in a post in another thread, I do not know these bikes, but as you are new here, I will at least give you an answer
As these are injection bikes, the ECU does know when to fire the plug. So my guess would be no wasted spark. But if you have a running engine, it should be easy enough to measure?
Regarding the radial (?) clutch pump, I cannot say, but I'm afraid that even the 16x18 might be a bit too big?
I even don't know what dimension the OEM pump on the fourstrokes was, but here is how I would go about to find out:
Check the parts lists for your bikes and a twostroke (EC300) for the same year. If the cluch masters have the same parts number, come back here and ask what diameter the twostroke pump is. I think it is around 10mm, but may remember wrong.
If you have the diameter of the OEM, there surely exists some formulas to calculate the diameter and lever ratio of a radial pump.
Good luck with your builds! Please post some pictures!
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 12-21-2020, 05:38 AM
I believe the standard master cylinder is about 9.5mm, but there are not many in that diameter available. My engine is at the moment buried under piles of furniture in my garage(wife insists I work on the house first.) So cannot see where the sensor is located.
2004 EC450 enginr Tony625 Parts 0 05-13-2020 06:11 AM
EC450 -10 wiring Svippen Enduro Engine 4 stroke (including EFI & Exhaust) 1 10-10-2016 05:19 PM
2010 gas gas ec450...$5,000 k_osborne Used Bikes 1 04-17-2013 10:51 PM
ec300 or ec450 fkmf6 General Discussions & Announcements 68 05-21-2010 02:00 PM
09 Ec450 Wiggy Enduro Engine 4 stroke (including EFI & Exhaust) 12 01-27-2009 09:33 AM
