Old 05-31-2021, 02:00 AM
dimtsam dimtsam is offline
Default Sachs shock lower bolt fitting
Hello
Im looking for the lower bolt fitting for my Sachs rear shock, like the one on photos. Does anyone knows how to search it or where to find something like that?
Old 05-31-2021, 10:07 AM
Zman's Avatar
Zman Zman is offline
I am not sure if your's is stripped or missing, but I had one of my Ohlins lower mount strip and I was able to fix it with a Helicoil. I needed to use a Dremel cutoff to shorten the Helicoil but it worked fine.
Old 05-31-2021, 10:55 AM
gasgasman's Avatar
These are inserts that go in the bottom of the shock clevis.
Presumably, so you can swap them out with different ones to change the ride height.
Old 05-31-2021, 11:56 AM
Is it safe to repair it with Helicoil?
Old 05-31-2021, 11:57 AM
Do you know where to search for these inserts?
Old 05-31-2021, 06:33 PM
GasGas's Avatar
GasGas GasGas is offline
I would put a helicoil in it.
2018 EC 300
Old 05-31-2021, 09:28 PM
gasgasman's Avatar
The shock bolt doesn't thread into these inserts.
Old 05-31-2021, 09:42 PM
gasgasman's Avatar
I don't.
You may have to find a machine shop that can make some for you.
Old 05-31-2021, 10:09 PM
gasgasman's Avatar
This is off the Aprilia forums.
Looks like what you need.
https://www.apriliaforum.com/forums/...ck-info-please
Old 06-01-2021, 02:32 AM
yes it looks similar. But in this case you can use hexagon bolt to the screw. In my GG the screw goes to the fitting. I think I will go to a cnc solution
Lower bearing replacement in Sachs rear shock Blambo Other GasGas Bikes/Quads 1 04-02-2018 12:51 PM
Flexx bars bolt hitting brake line/fitting shang Enduro Chassis & Body 4 03-25-2015 09:23 PM
2009 sachs fork lower pinch bolt Diggs345 Enduro Suspension 2 05-21-2012 01:22 PM
Anyone tried removing center bolt on lower triple clamp with sachs forks 2011? Simmo737 Enduro Suspension 12 09-14-2011 11:06 PM
Lower pinch Bolt stay_upright Enduro Suspension 2 07-21-2008 05:14 PM
