Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Trials Technical Forums > Trials Chassis & Body
Trials Chassis & Body Trials Frame, Plastic, Brakes, Bars, Controls, wheels, tires, sprockets & gearing.
Old 05-04-2023, 03:23 PM
btcca4's Avatar
btcca4 btcca4 is offline
Default 2008 Raga 250 Rear Brake Height Adjustment
What does Gas Gas use as a rear brake height adjustment? There is no 6mm adj screw? The only thing on the frame is a welded-on tang that the lever hits, but it is quite far away making the rear lever higher than I want. I don't see anything in the parts catalog?
Thanks!
Old 05-04-2023, 06:58 PM
(F5)'s Avatar
(F5) (F5) is offline
Strange. On my 14 TXT250 the lever itself has a cap head screw in it that bears against the swingarm pivot circle of the frame.
Check lever for threaded fitting. Could add something there if not.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 05-04-2023, 08:39 PM
btcca4's Avatar
I did, nothing there.. Even pictures of spares don't show an adjustment bolt. I'll make something. Thanks!
Old 05-05-2023, 12:02 PM
cbutler's Avatar
cbutler cbutler is online now
Call Jim Snell he will tell you
http://www.trialspartsusa.com/index.html
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 05-05-2023, 04:06 PM
(F5)'s Avatar
Confession time. Mine has an aftermarket lever. I did especially go downstairs to look.
. . . But didn't check the spares box that would have the original.
Quick Google comes up with this.
https://www.enduropuro.it/shop/en/fr...s-txt-pro.html
I think mine is another brand so look around.
That being said, I also found this.
https://www.bike-parts-gasgas.com/ga...rts/BE25922018
'07 EC300 GG
'14 TXT250 GG
'21 XTrainer
Rear Brake Pedal Height Adjustment ssaulnier Enduro Chassis & Body 6 09-04-2019 04:36 AM
EC 250 2008 Nissin master cylinder lever stroke adjustment iconic Enduro Chassis & Body 0 04-14-2014 03:11 AM
Steering lock/Brake pedal height adjustment fletchman45 Enduro Chassis & Body 14 06-04-2013 11:52 AM
Lowering Rear Brake Pedal Height? 2whlrcr Enduro Chassis & Body 9 08-29-2010 06:17 PM
Rear brake adjustment Silver Enduro Chassis & Body 5 06-03-2009 07:50 AM
