Old 09-07-2023, 07:30 AM
Karjis Karjis is offline
Default How to calibrate speedometer for smaller wheels?
Hi! I'm changing from enduro rims (21") to smoto rims (17"). How can i calibrate the speedometer for smaller rims? My bike is GasGas EC 300 Year model 2005.
Old 11-17-2023, 05:18 PM
ditezz ditezz is offline
You need to change the wheel size in your speedo set up .Masure the wheel diameter (in inches or millimetres)You do this by marking tyre and floor with chalk and push bike one wheel revolution ,make another mark and then measure distance between both marks .This is the measurement you need to put into your speedo setting for wheel diameter .You need to enter the setup on your speedo ,scroll thru to wheel diameter and enter new info .Good luck
2007 Ec 300 speedometer Jonas300 Enduro Electrical & Wiring 4 04-29-2018 03:12 PM
Speedometer reseting ismael Enduro Electrical & Wiring 8 05-21-2017 12:29 PM
2011 xc 300 odo/speedometer ? Muddy General Discussions & Announcements 48 07-22-2013 10:38 AM
Clearance with a smaller silencer celler Enduro Engine - 2 stroke 2 03-04-2013 09:36 AM
