Old 11-29-2023, 06:35 PM
elnonio elnonio is offline
Default 2023 Rieju Racing 200 LED relay
Trying to understand. The 2023 Racing comes with a relay, that should be LED-capable (the manual says diodo, so should be LED). But when I plug in a single (in case that matters) turn signal, it doesn't flash as much as just dims.
It may be a case of plugging two on one side, I suppose. I just did a Wr250F conversion, and one signal alone worked fine when testing the wiring.
Thoughts?
Old 11-30-2023, 07:09 PM
So it has nothing to do with 2 or 1 LED units. 2 made no difference, but hooking up a regular bulb resulted in blinking.
Just need to find a replacement LED relay which this clearly ain't.
2023 Rieju 300 factory jets. Ud_luz Enduro Intake/Carburetion - 2 stroke 1 07-03-2023 03:29 PM
flasher relay pigpen966 Enduro Electrical & Wiring 2 07-12-2018 05:22 AM
2010 relay prob? nato Enduro Electrical & Wiring 0 02-16-2012 02:31 AM
Indicator relay Hicksi Enduro Electrical & Wiring 5 08-22-2011 09:52 AM
fuel relay Devondan Enduro Engine 4 stroke (including EFI & Exhaust) 4 10-21-2009 04:12 PM
