Old 12-28-2023, 10:37 AM
Lostcause Lostcause is offline
Default 2007 ec300 No lights
Hi!
I have a 2007 ec300 which I put away a couple of months ago due to a shiny new bike & it was working perfectly, now I've dug it out to check over & prep for a mate to have a play and there are no lights at all! The garage is slightly damp (just incase there's anything known to suffer)...
The regulator has had a hard life so I put a new one on for good measure & this has made no difference.
I read around 35v ac on the yellow wire from the stator, same at regulator & same on the headlight connector.
I can see nothing obvious, the headlight works fine off a battery. I've tried the headlight on bike without the tail light connected & vice versa with no joy.
Any suggestions or any common issues to look for?
Cheers- Steve
Old 12-28-2023, 01:35 PM
SS109's Avatar
SS109 SS109 is offline
Check the light switch. The contacts in them can get corroded when sitting. I've had to clean more than one of them to get them to work.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 12-29-2023, 08:56 AM
Default All sorted
Thanks.
Turns out it was a bad ground connection due to fresh powder coating on the frame. I should've checked that sooner but it didn't occur to me initially since all had been working fine 🙄
Old 12-29-2023, 01:35 PM
SS109's Avatar
Glad it was a simple solution!
'11 EC250R
'98 KDX220
2006 ec300 wiring/lights clyde34 United Kingdom 2 09-07-2023 08:51 PM
2007 ec300 Ud_luz Used Bikes 7 02-16-2020 01:51 AM
All lights blinking EC300 2007 stian Enduro Electrical & Wiring 24 08-23-2014 03:35 PM
2005 EC300 vs 2007 EC300 alecsstefan Enduro Engine - 2 stroke 19 01-22-2010 01:40 AM
