Old 01-11-2024, 03:07 PM
Fitzynkaz Fitzynkaz is offline
Default Swing arm help
Hi,
New to the forum after recently buying a 2017 ec250 racing
I need to replace the swing arm bearings /bushings and cannot for the life of me find the 2017 ones
Some people have said they diddnt change from 2011 to 2019 but I'd rather know for sure off someone who has replaced them on a 2017
All balls list all years except 16 and 17 from what I can find
Can anyone advise
Many thanks alex
Old 01-11-2024, 09:56 PM
gasgasman's Avatar
2018 on up are different.
Stay away from All Balls. Cheap Chinese junk.
I've had good luck with Factory Links.
https://www.cpd-usa.com/shop/sak-g-0...ing#attr=18024
Old 01-12-2024, 06:18 AM
Anders's Avatar
Anders Anders is online now
Originally Posted by Fitzynkaz View Post
Hi,
Can anyone advise
Many thanks alex
I don't know about the 11, but I know that the 06 and 15 link bushings are different. I think also the swingarm bushings differ. The 18 and 19 is something else, I presume, as the complete chassis is different.
The 17 chassis is the same as the 15. I recently bought the swingarm and link bushings for my 15 from the Norwegian importer who got them from Spain (Rieju, I presume).
I All Balls lists 14 and 15, they should also fit 17. I'm pretty sure about that, as the 17 is only a 15 with slightly different decals.
The bearings can be found in any good bearing supply, they are HK2216 and DL 2216
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 01-12-2024, 03:02 PM
Thanks everyone I will look into it
Old 01-12-2024, 03:05 PM
I have attached a pic of said bike the logbook says ots a 2017 but may be registered late ? Really not sure...but was bought as a 2017
Old 01-12-2024, 03:20 PM
farmerj's Avatar
farmerj farmerj is offline
Good looking bike. While not the answer to your original question - I'm with gasgasman. I've found Factory Links to be of good quality and excellent customer service. I would recommend!
Jeff
'18 GG XC 300
'05 GG DE 300
'01 GG txt 321
Old 01-13-2024, 12:35 AM
cbutler's Avatar
cbutler cbutler is offline
Jeff
Top notch been buying from them for years
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 01-13-2024, 04:25 AM
Anders's Avatar
That is an 18 model as far as I can see
Anders
1986 Duc Mille S2
etc
Swing Arm CanGasser Enduro Chassis & Body 0 09-08-2016 12:05 PM
Swing arm Nut Danj56 Enduro Suspension 2 02-22-2016 10:35 AM
Need swing arm plugs! HooliKen Enduro Chassis & Body 6 01-19-2016 05:01 PM
Swing Arm Assembly mcnut Parts 1 12-09-2014 09:39 AM
07 swing arm ? REVERUP Enduro Chassis & Body 12 04-29-2007 08:59 PM
