Old 02-17-2009, 03:30 AM
stay_upright's Avatar
stay_upright stay_upright is offline
Default Marzocchi 45mm Questions
OK finally started servicing the forks plus I was going to stiffen up the rebound stacks.
So Q1 - I bought replacement dust seals - oil has been weeping past the seals on both fork - should I be replacing the oil seals as well - I didn't realise the dust seals were not the oil seals but I think in the UK it is common only to replace the dust seals when the forks are leaking a bit...
Q2 - Does the standard spring pre-load tube look like the picture in the manual? The reason I ask is mine looks a lot longer - maybe it has been replaced in the past...? Any measurements for what it should be? I'm guessing mine is about 2" long.
Q3 - Are most people running 90mm oil height, I was using 140mm last time - this was tuned to resist bottoming so maybe I need to go with 90mm but run less preload (if mine is in fact more) and/or reduce stiffness in the compression stack..
Anything else I should be looking for/doing while I've got them apart.
One final thing - I've made a Word document from the PDF manual cutting out all non-english bits and rubbish - the idea being I only need to print 21 pages not 118 would the admin be interested in putting this in the manuals section along with the original manual?
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 02-17-2009, 06:45 AM
rpduc rpduc is offline
1. By all means if you have them apart anyway replace all of the seals. Also check the bushings for wear.
2 & 3. http://www.gasgasrider.org/forum/sho...2&postcount=14
The rest of that thread is very informative as well.
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
'07 Duc S2r 1000 still rubber side down...
May be so... May be not so...
My Website
Old 02-17-2009, 07:18 AM
Hi - just been reading that post and another related to Pobit.
I've found a mention of 5mm preload on the fork springs no mention of how long the pre-load tube is as stock.
As for seperating the upper/lower fork tubes the manual says just pull hard - any comments - how hard should I be pulling? Can i damage anything?
It looks like the lower bushing is contacting the upper bushing when trying to seperate the tubes - is that right? Do you just end up pulling the lower bushing out?
'05 Gas Gas 300
'99 KTM 200
Old 02-17-2009, 07:53 AM
I only had my buddy's 45mms apart once about a year ago (I have 50mm on my MC) and I can't remember if the spring preloads when you screw the cap to the inner assembly or when you put the cap into the tube but either way you should be able to measure the preload as you assemble it no? I'm sure someone more familiar with the 45s will chime in.
Make sure you have the keeper ring out of the oil seal before you pull hard.
I just kinda use the bottom tube like a slide hammer and carefully tap out the oil seal. Yes the top bushing hits the bottom and both bushings come out. It's pretty clearly depicted on page 68 and 70 of the Shiver manual.
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
My Website
Old 02-17-2009, 08:15 AM
Thanks - I'm not 100% on what the preload should be though...
Yes I remover the spring clip
'05 Gas Gas 300
'99 KTM 200
Old 02-19-2009, 09:49 AM
Still trying to get the tubes apart - damn they are tight. In the manual it just says 'pull'
I don't want to hammer them in case I damage something...
'05 Gas Gas 300
'99 KTM 200
Old 02-19-2009, 11:04 AM
Nick's Avatar
Nick Nick is offline
Like said earlier you slide hammer them apart. Dont worry.
Old 02-19-2009, 09:03 PM
crem55 crem55 is offline
check this link out it shows you and there is part 2 also
http://www.youtube.com/watch?v=Y43k1qFVGW4
http://www.youtube.com/watch?v=C9ICr...eature=related
Old 02-20-2009, 05:33 AM
That's great - what a good guide!
'05 Gas Gas 300
'99 KTM 200
Seal replacement on conventional 45mm Marzocchi? renotsttam Enduro Suspension 6 06-14-2015 01:29 PM
Marzocchi 45mm mid valve check plate stay_upright Enduro Suspension 10 04-02-2010 12:37 AM
Marzocchi 45mm Shiver manual super_rat Enduro Suspension 1 01-01-2009 10:24 PM
Marzocchi 45mm bushes iancp5 Enduro Suspension 0 02-25-2008 02:49 AM
