Old 08-24-2009, 01:44 PM
mountainman mountainman is offline
Thumbs down No service manuals - What a JOKE!!
I can see why GAS GAS is not growing like KTM - they don't even produce a service manual for there Enduro bikes - I had always been afraid of the day when I had trouble with my 06 450 FSE - finally its happened - and now I cant find any way to get the electrical - computer - service reading codes etc... I cant even find what readings for the coils. After research I found all Gas Gas produces is frame & body - and Engine - nothing on electrical - I live in Colorado and no one really knows about the fuel injected enduros - it also seems that no one in the USA knows much yet. Can anyone set me straight and tell me different?
Old 08-24-2009, 02:04 PM
cbutler's Avatar
cbutler cbutler is online now
Have you tried to call GoFasters 1-877-363-8767 I bet they will help
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 08-24-2009, 02:12 PM
Thanks for the info -- yes I have talked with them and they said I could send in the computer and they would put it in another bike to see if it would work - but they said there is no guides to trouble shoot the bike yet - I would like to do everything 1st before I send things in -
Old 08-24-2009, 05:01 PM
Qui-gon's Avatar
Qui-gon Qui-gon is offline
There is a wiring diagram for an 05 here:
http://www.gasgasrider.org/forum/showthread.php?t=2466
but that is about it for electrical service stuff. What is the problem with the bike?
Old 08-24-2009, 08:23 PM
MattR's Avatar
MattR MattR is offline
Not true... there are manuals on the GasGas Corporate site and they are FREE! KTM makes you pay for the manuals. Granted, the GasGas ones are not the best but the service manuals (called "taller" in spanish) gets you through basic teardown prodecures. The owners manual and parts diagram are also available.
I will provide a few links for convenience, but you may want to browse through their other model years. Many items cross over between years. NOTE: the taller/workshop manual was only made in limited years. Same for us 2T guys.
http://www.gasgasmotos.es
Located under User Manuals > FSE/FSR
2005 Workshop/Service Manual:
http://www.gasgasmotos.es/rcs/manual..._fse05_eng.zip
EDIT: There is also some fuel injection software and maps listed on the GG corporate website.
Another place to look is the GasGas USA website. Although, there may not be all manuals like the corporate site.
http://www.gasgas.com/enduro_home.htm
Matt
Current: 2009 Yamaha FZ1
Old 08-24-2009, 09:02 PM
MattR's Avatar
Default How to find the GasGas manuals....
Refer to yellow circled areas to find the manuals easily.
GasGas 4T Manuals:
GasGas 2T Manuals:
Matt
Old 08-24-2009, 10:00 PM
Wiggy Wiggy is offline
Anyone seen an engine manual for the 08/09 450's ?
Old 08-25-2009, 08:05 AM
Thanks for the help - I have already downloaded the manuals. Nothing on the electrical system readings - Voltages - Coil -etc..
The bike is not triggering the fuel injection and not turning in the Speedo - it will crank the engine over but is getting the wrong signals. The cooling fan will even come on when you turn the key on and it is cold.
Old 08-25-2009, 08:55 AM
jostby jostby is offline
Ground issues will cause problems similar to what you describe when one device tries to ground through another. Start with the basics... remove all the plastic, tank, and seat and then remove and clean all the ground connections. Also check for wiring that appears too tight at loom splits and where the wiring is secured to differant areas of the frame, it can be damaged in those areas but not visibly.
But number one thing is make sure the battery is good. Batteries can turn to junk yet still have enough amperage to crank the engine. But there won't be enough voltage to fire the electronics. Take it somewhere and have it tested if you don't have a load tester to do it yourself. Or put a voltmeter on it while you crank the engine and watch the voltage. Most ECU electronics won't work without 12 volts where the old contact point and first generation electronic ignitions would fire with 9 volts. Low voltage will cause relay problems that can cause symptons like yours also but not as common. Good luck.
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 08-25-2009, 09:14 AM
Qui-gon's Avatar
Check the EFI relay under right hand number plate..it is a common problem and easy fix. There are also 2 fuses associated with the EFI. One is the supply line for the fuel pump.
06 Gas Gas FSE 450 USA
How to find the GasGas manuals... MattR General Discussions & Announcements 60 10-11-2022 09:20 AM
Sachs manuals? Krasi Enduro Suspension 2 11-07-2008 05:16 AM
workshop manuals gone? jostby General Discussions & Announcements 3 10-26-2008 12:29 PM
All GG manuals available on GasGas USA website! MattR General Discussions & Announcements 2 01-01-2008 08:38 AM
Manuals skid jackson General Discussions & Announcements 2 09-15-2006 10:09 AM
