Old 03-21-2010, 01:41 PM
dank's Avatar
dank dank is offline
Default And then this became a problem.
my clutch drags. bad. it will start moving the bike with the clutch full in. i was wondering if bleeding the clutch would help this? seems like it would, because if theres any air in the lines, then it wouldnt move the plates apart like its supposed too. i was wondering what you guys thought, as to weather or not it would work.
03 ec250
hyde skidplate, cycra handguads, protaper contours
"what? it seemed like a good idea at the time!"
Old 03-21-2010, 02:08 PM
(F5)'s Avatar
(F5) (F5) is offline
If your clutch gets air in it it will cause that, but likely it will be like a super light lever & like no action from the lever. Like zipo.
Otherwise do a search the topic has been covered many times. Mine required filing marks out of the basket & everyone has their opinion on which magic oil to use.
Old 03-21-2010, 06:53 PM
dank's Avatar
is there any other way to adjust the clutch?
03 ec250
Old 03-21-2010, 08:14 PM
gg3's Avatar
gg3 gg3 is offline
Hi Dank,
I had the same problem with my 2002 300 when I first got it.Bled the clutch countless times,from the bottom,from the top,syringes,clutch bleed kits,nothing worked.Then checked & replaced my clutch springs,filed the basket,Replaced the plates with little difference.Then got onto this site & went to a light oil.USA guys swear by amsol or rotella,we don't get either but ended up using Rockoil GRO light gear oil.Noticed a difference straight away but it got better after another oil change,I guess residue from other oils left on the plates? Point is get the right oil first,it's a cheap fix.
Old 03-21-2010, 08:22 PM
dank's Avatar
so like amsoil 0w 40 or rotella of some sort? hmmmm. but ya its bad. the bike will start to move with the clutch in. eek.
thanks! any particular weight i should try? (i. e 10w30 0w40 etc....)
03 ec250
Old 03-21-2010, 08:31 PM
gg3's Avatar
gg3 gg3 is offline
So was mine,If you sat with the clutch in it would try & creep forward or just load up & stall.0-40 seems to be the general opinion
Old 03-21-2010, 08:47 PM
dank's Avatar
alright sounds good! Thanks! also, you wouldnt happen to know any other brand of throttle cable that would be longer than my stocker and would fit? i put pestrana fmx protapers on and they are about an inch and a half taller, so now the bike accelerates violently every time i try to make a right turn, without me twisting the throttle. not cool
03 ec250
Old 03-21-2010, 11:15 PM
gg3's Avatar
gg3 gg3 is offline
No,sorry.Never had to replace a cable on mine.Could re-routing the cable solve this?
Old 03-22-2010, 12:25 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
Call Go fasters for the longer throttle cable and then ensure it is routed as per the good book.
As far as oilos in clutches, I had a similar problem and now use GRO gear oil.
All good now.
Cheers Mark
Old 03-22-2010, 07:58 AM
dank's Avatar
i dont think so. its routed properly, just too short because i have way taller bars. the pastrana fmx bars are about an inch and a half taller than the protaper EVO bars i did have. im going to call gofasters later today. thanks guys!
03 ec250
EC 300 problem!!!!!!!! clerky clerk Enduro Engine - 2 stroke 31 07-06-2011 05:19 PM
Downshifting problem Metalefty Enduro Engine 4 stroke (including EFI & Exhaust) 13 10-15-2008 05:31 PM
50 boy problem Sharpie Mini Gasser 's Corner 3 09-04-2008 03:58 AM
07 FSR 450 injector problem? GavGav Enduro Engine 4 stroke (including EFI & Exhaust) 14 03-10-2008 05:51 AM
I think I have a problem SpeedyManiac General Discussions & Announcements 7 11-30-2007 11:26 PM
